How can i turn off the password on my router - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
You might have to set it back to factory default settings depending on the brand/type of your router on some routers theres a hole in the front the same as a modem which you press a pin inside to reset
hope this helps
Posted on Nov 10, 2010
Router light turned into orange after changing password.
Hi Shaifali,
No worries!
- Can you log back into the router? with the new password or with the old one?
-Has your router been totally re-setted to factory defaults?
- I think you have changed the PPoE connection password which is the internet link password to ISP instead of the router password?
Let me know these questions and I will help you resolve this issue
Feb 27, 2014 | Belkin Basic Wireless Router
Hi i have foggoten my pass word to my router and need to change the security settings to stop some one having access thanks Chris
If some one is accessing the router it's probably because there is NO PASSWORD, on the other hand if you had a password and gave it to that persone and can't remeber it you need to RESET the router to factory default (according to manual) than re-configure the device... (with a good password that you will remember)...
Sep 15, 2011 | Belkin F5D7234-4 Router
Netgear will not accept my password
Well, there are two possibilities: 1) You don't remember your password correctly 2) Some electronic failure messed up your password settings I recommend you to reset your router and reconfigure it, first turn off your router then reset your router by using a small pin or tooth pick and putting it in a small hole in the back of the router push just a little the reset button hiding in the hole for about 5 seconds and turn your router back on, the use default username and password to log into the router config, set up a new password and you're done. Have a nice day :)
Mar 30, 2011 | Computers & Internet
I forgot my password.
Take one Norwegian paper-clip, and straighten one end.
Turn the router off.
Insert the end of the paper-clip into the small hole in the back of the router, and hold it pressed-down for a few seconds.
This will reset the router to its "factory" settings,
including the default password.
Turn the router on, and configure it.
Sep 20, 2010 | Belkin (F5D5231-4) Router
I forgot my password i have a sheet that says router username and router password but they are not working
Hi Friend,
If you have forgot the password then we have to reset the router to its factory default settings so that you can re-configure the settings (since the password of your choice is not working)
In order to reset the password please follow the steps:
1. At the back of the router there is a small/tiny button (red/black), this is the reset button.
2. Push and hold this button for 30 seconds(make sure the router is turned on).
3.After 30 seconds turn the router off and wait for another 30 seconds.
4.Turn it on and reconfigure the router as per your requirements.
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys WRT120N Router
Lost my pass word wireless router linksys by cisco
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Apr 23, 2010 | Linksys Wireless-G Broadband Router
Trouble hooking up router
Wireless May need to be turned on in the router if this is wired and wireless router. After your router is hooked up to your net work with any pc that is connected to it by a wire try typing in your webbrowser 192.168.1.1 this should open the routers web based interface. you may need to look through your packaging for your default password or you can try. admin for user name and admin for password or adminadmin for password. you can also look online for your router brand and model for the default username and password. once you have access to the router then you can turn on your wireless settings and set your encryption typ and passwords for others to use if you choose.
Mar 31, 2010 | NetGear RangeMax WPN824 Router
Reseting and getting to password page
Press and hold the reset button of the router for 30 seconds. Turn off the router and then turn it back on.
To access the web interface, type www.routerlogin.net in the address bar of IE or any browser.
User Name: admin
Password: password
Hope this helps!
Feb 21, 2010 | NetGear WGR614 54Mbps Wireless Router...
Forgot router login for netgear router wgt624
Reset the router from back , Hold the reset key for 30 sec , Make sure router is powered on , Turn off the router for 30 secs and then turn it back on , Your router login would be username : admin and password : admin factory default
Regards:
Chandan
Sep 07, 2009 | NetGear WGT624 Wireless Router
Can not coneect wireless router to ps3
If you received an error code, that's probably an incorrect wireless password. To verify the wireless password, open the router's admin page using IE and look for wireless security. If you are sure about your password, try to change the wireless channel of your router to channel 11 and power cycle your router by turning it off for 30 seconds then turn it back on.
Apr 15, 2009 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
12 people viewed this question
Alun Cox
David Payne
David Payne
