Question about Lexmark Wheelwriter 10 Series II Typewriter
The wheel gets stuck around the middle of the carriage and even when pressing the margin release key it will not return to the beginning. Any suggestions???
  • Lexmark Master
  • 3,594 Answers
Turn it off, put a little WD40 on the silver shaft that the carrier slides on, if you know how to remove the case put some WD40 on the bearings of the carrier motor in the right rear of the machine. If all this dosen't help look for debris in the carrier area, as a last resort remove the batteries. turn it off wait a minute and restart.
DickyO
Posted on Nov 10, 2010
My carriage return is stuck between 70 and 80 and I don't know how to get it back to 0 to 10. I hit return and the carriage goes back to between 70 - 80.Can you help me?
Return to the L. margin, touch and release the mar rel key, backspace to where you want the margin, press L. mar. key.
DickyO
May 20, 2010 | Nakajima AE-710 Typewriter
AE-710 Typewriter: My carriage return is stuck between 70 and 80 and ...
Return to the L margin, press don't hold the mar rel key, backspace to the desired location, press left mar. key. The R. margin works the same.
DickyO
May 18, 2010 | Nakajima AE-710 Typewriter
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
IBM selectric II carriage stuck in right margin
There is a thin metal ribbon in the back that has come off the wheel. It is a devel of a thing to get back on.
Remove the cover and watch ... you will see what I am talking about.
It may have come un-attached ... equally difficult to fix without the little thingie the typewirter mechanic uses.
good luck
Oct 14, 2009 | Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
I have the left margin stuck in the middle of the page and I cannot get it to release and move it to the left. Help please!
I'll try, return to the margin, touch and release the mar. rel key, backspace to the place you would like the L. margin, press the L. margin key.
DickyO
Oct 13, 2009 | Nakajima AE-830 Typewriter
MY SWINTEC 7040 WON'T RELEASE MARGIN.
Return to the L. mar. press and release the mar. rel. key, backspace to the place you want the margin press L. mar. key.
DickyO
Jan 16, 2009 | Swintec 7040 Typewriter
Carriage return problem
The tab button may be stuck or the carriage release lever is stuck or a broken escapement.
Dec 24, 2008 | Smith Corona Wordsmith 100 Typewriter
Margins will not reset
Return to the stopping point, press and release the mar. rel. key backspace to the left then press L. mar. key.
To clear tabs tab all the way yo the rt. press & hold tab clear touch ret all tabs should clear.
Hope this is helpful
DickyO
Jul 11, 2008 | Nakajima AE-740 Typewriter
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Lexmark Wheelwriter 10 Series II Typewriter Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
