Question about Imperial IR-6-G24 Elite Gas Kitchen Range
Broiler doesn't seem to cook or broil fast enough not hot enough under griddle. I have IR-6-24-cc model 6burner griddle/broiler with conection ovens.also right oven has a loud roar when starting&cooling down. Left side sounds great.very quiet running. Need parts & operations manual for me an employees.Thank you so much.
  • Imperial Master
  • 43,501 Answers
There is probably a separate gas pressure regulator for different parts of the range... they are know to stick and they can either stick in a high pressure mode or low pressure.... I would first change out the regulators and see what happens before going any firther with your troubleshooting....
I am also assuming that the burners are clean and free of grease, etc...
sounds like a gas problem to me...get a gauge on the manifolds and see what is happening there...
heatman101
Posted on Nov 12, 2010
How do I fix broiler that does not burn hot enough to broil. Oven works o.k. Broiler worked last week but now flame is not strong enough.
Make & model? You are talking about flames so I assume it is a gas unit. I would examine the broiler burner, sounds like a problem there.
Nov 29, 2014 | Kitchen Ranges
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
What does a broil pan do
The broil pan is used to broil meats such as steak or chops. the top part has slots that allow the grease to run into the lower part. they are usually under the burner in the lower door. but some ovens have the broil element in the oven proper. then the pan should be placed within a few inches of the broil element. You should monitor the cooking process because the broiler heats the food very quickly and could burn very fast.
Mar 15, 2014 | Ovens
I have a Kenmore 790.94479801 electric range. While using the Bake function, I noticed that the broiler element was on and the oven had gotten very hot. I hit the Stop button and noticed a small puff of...
When the broil function is off, check for continuity between the broiler relay output terminals. If there is no continuity, check for an external short. If there is continuity when the broiler is supposed to be off, you need to replace or repair the board.You can get your old board repaired at appliancetimers.com.
Mar 18, 2011 | Kenmore Kitchen Ranges
Have a GE gas range. Broiler doesn't work while
First clean the terminals at the control and check for tight wires at the incoming terminal block. Check the neutral wire for a good conection. If the ignitor reads less than 3 amps it does not have enough resistance to open the gas valve. Turn the gas off. Put a clamp on amp meter on the broil ignitor wire. Turn the broiler on. If less than 3 amps.replace the ignitor.
Sep 30, 2009 | GE JGBP28 Gas Kitchen Range
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
Imperial IR-6-G24 Elite Gas Kitchen Range Logo
62 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
