Question about Maytag MAV8600 Top Load Washer
Washer fills with water but will not do anything else. I'm not sure of the model #but I think it is a 1994 model.
    President:
  • 1,654 Answers
Probably the timer on this is bad?
Posted on Nov 10, 2010
My ge top load washer wont start already change out board. not sure if my lid switch or magnet is bad?
Sure does sound like your safety switch isnt working. To be sure please give me model number to unit and I can do some checking and get right back to you
Apr 11, 2015 | GE Washing Machines
Washer fills with water and stops
You possibly could have a bad lid switch. The machine may think you still have the lid up and that is why it stops and will not do anything else.
Feb 10, 2015 | Roper RAS8445KQ Top Load Washer
Washer won't fill with water
Hi Allen, this is JK. I see that you are having trouble with your washer (FEX831CS) not spinning or filling with water. For the washer not spinning, check the drain hose length and make sure there are no restrictions. The concern could be with the timer or the drain pump. For the washer not filling, I would check the water pressure, pressure switch and the water inlet valve. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Mar 23, 2014 | Frigidaire FEX831CS Top Load Stacked...
My neptune washer has an indicator light that reads 'nf'. Can't find anything in the manual?
The washer has tried to fill and could not. Make sure the water faucets are open all the way.
Check for kinked hoses.
See error codes2_bing.gif on page 12 of the manual.
Dec 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Good luck.And please do rate my answer.Thank you.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Model MAH8700aww washer
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Dec 12, 2008 | Maytag Washing Machines
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 Series Model 110.20862990 Type 111
no the timer doesn't control the water fill the pressure switch does you have three possibility's either the pressure switch is malfunctioning or a water valve is hanging open or the pressure switch pressure hose is leaking or off the tub the pressure switch is connected to the knob that lets you select the water level in the tub if you back out the two screws on the front or back of the end caps depending on the model you can pull the control panel forward and tilt it back to access the pressure switch its gold in color and has a clear latex hose attached to it also take the hose loose and blow through it to make sure its clear with the washer empty of course lol if you need more info just reply to me be glad to help water can also leak out from the pressure switch hose if a mouse has chewed through it or its come loose from the tub
Mar 18, 2008 | Kenmore 24902 Top Load Washer
Open Questions:
Maytag MAV8600 Top Load Washer Logo
63 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
