Question about Maytag PAV2300 Top Load Washer
Washer not spinning as well now timer sounds like it is humming and smells like it is burning no cycle works
    President:
  • 1,654 Answers
Definatly sounds like the timer has burned up and is stuck on one of the contacts
Posted on Nov 10, 2010
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
It made a quite hum during the spin cycle, instead of the normal (much louder) spinning sound. When I turned it off I noticed it had a rubber/electric burning smell.
If it's a squealing sound, your belt is probably bad. If it's a humming noise with those smells you listed, it might be your transmission going bad.
Nov 02, 2009 | GE WBSE2090A Top Load Washer
Burning smell and washer will not spin
The buring smell could be coming from the belt, try looking to see if the belt i burnt or broken
Nov 22, 2008 | Whirlpool LSN1000LW Top Load Washer
Frigidare top loading washer 6 cycle - 10 years old
you may want to inspect the bottom part and see if it still uses fan belt. it could be that the belt is loose and the motor is spinning but can not drive the transmission. so the rubber burning smell is coming from the slipping belt.
the solution is to tighten the belt or replace it if necessary.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
Maytag PAV2300 Top Load Washer Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
