Question about cdv Software Entertainment Lula 3D
Error: Model not found f:lola 3d/run/binkobject.v3o
Whart are the normal settings of tension for this machine
Have you checked the manual? Usually start with a mid setting - but it depends on the fabric also. I found a free copy of the manual online and it says to start with 5.
Hope that helps.
Lola
May 28, 2013 | Brother LS-1217 Mechanical Sewing Machine
I must be desperate if i'm trying to get help *here*.. i've only ever seen noobs with 'where's the trash folder' or 'i wanna crack '.. but i'm pissed ..i bought a game called 'egames pinball' and it...
I would right click on the program and run it in compatibility mode for the operating system it was designed to run on. I would also try to update my graphics card drivers.
Mar 29, 2011 | Computers & Internet
While loading ulead cool 3d in windows 7 I get an error saying that a dll could not be found. It worked in XP
Some programs will not work with 64 bit windows, that did work on XP. You can try to run the program in compatability mode, but still, if the program is not 64 bit capable, you will need a later version....
Oct 09, 2010 | Ulead COOL 3D 3.0 Upgrade Version for PC
D3D Drivers with Hardware Acceleration
Hi. I am getting an error "No D3D Drivers with Hardware Acceleration Found" when i start the Project IGI game. How to resolve this ?
Feb 10, 2010 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
I bought acre p221w monitor recently and now I can't play my mahjong master 5 anymore. Error message indicates that I need some kind of 3-d video card.
You must ensure that you have the setting for 3D available in the monitor's settings. If so, just find where that setting resides, and implement the 3D setting for your monitor. The monitor comes with a pretty extensive manual and if you don't have it, then go to Acer's web site and find the manual, by using the monitor's model number as your search key. Once you've found the monitor, download it - it is usually in PDF format - and then look through the manual, using the monitor's model as one search key, and find the section for 3D. Then go to the settings section, and follow to the letter what it says about how to set the 3D on that monitor and, as Michael Jordan says, "Just Do It!" You can do it easily and get it done the right way.
Enjoy!
Jun 06, 2009 | Dell Microsoft Windows XP Home Edition
Won't run. d3drm.dll not found error message
Get the file from here: http://www.dll-files.com/dllindex/pop.php?d3drm
when its done downloading copy this file into..  Main OS Disk (C:) > WINDOWS > system32.
When done, re-start your computer and run the program again. Hope i helped, Yuri.
Apr 25, 2009 | Broderbund 3D Home Architect Deluxe 6...
I recently bought a HNC model CTGJD2028 3D Optical USB Plug and Play Mouse for my Compac Deskpro EN running XP Pro. Plugged mouse into usb port. Get a Popup Bubble – Found New Hardware – Mouse. Message...
UPDATE YOUR WINDOWS SOFTWARE FROM MICROSOFT OR YOUR VENDORS SITE, THERE MAY BE MORE SOFTWARE PATCHES FROM THE VENDOR TO FIX THAT TYPE OF PROBLEM
Aug 11, 2008 | Computers & Internet
Problem
You may have to update Directx to V9 for XP, also check to make sure that the Acer meets the minimum system requirements that the game needs to run (will be found on the box or CD sleeve).
Jul 15, 2008 | Acer Aspire 5050-3242 Notebook
Video Game Consoles & Games Logo
100 people viewed this question
Top cdv Software Entertainment Video Game Consoles & Games Experts
James Wishart
Are you a cdv Software Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
