Question about Kenmore Washing Machines
I have a 10 year old Kenmore washer that has suddenly stopped working. It is full of water ( and clothes) and will not go into any cycle.Nothing happens but a ticking sound for a few seconds, then it clicks & stops.
    Top Expert:
  • Kenmore Master
  • 8,686 Answers
Possible drive belt broke or motor quit or pump not working
Posted on Apr 14, 2018
  • 15,935 Answers
The timer is what appears to be failed in this problem.
Typically - units are only supported for 10 years - but head over to RepairClinic.com and enter your full model number. If the part is available - it is very easy to change.
I can look for a replacement timer for you if you want - simply reply with your exact model number and I will respond with a direct link... as well as replacement instructions.
Thanks!
Posted on Nov 10, 2010
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Jun 14, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
I am washing clothes in a borrowed Kenmore washer. It's probably 10 years old. It stops short of completing the Rinse cycle and never makes it to the Spin cycle. The bowl will start filling up w/ water,...
This is a typical problem with the "lid switch" on the washer. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 26, 2011 | Kenmore Washing Machines
Kenmore washer model 11029832800 stopped working!
Check the lid switch. If this is bad then it will not run through the cycle. An easy first thing to check anyway. Should be able to ohm it out. Make sure the contacts are opening and closing.
Apr 29, 2010 | Washing Machines
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Washer stops suddenly and water isn't drained out
Hi tieuvodanh; Sounds like the timer has gone out. If you can advance the selector dial manualy, and the machine continues to operate as it should, then this is the problem. Replacing the timer will require some advanced knowledge of washers and the ability to use a box of hand tools. A good handy man will be able to repair this for you. Best regards; HELP2DIY Please don't forget to rate my answer.
Jul 10, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
41 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
