Question about Whirlpool Duet GHW9150P Front Load Washer
I keep getting F21 and sd on my washer. I have cleaned out the drain hose which now drains well. I assume the drain problem is an internal problem. Anything else I can do or do I need a repairperson? I have a hunch I just have a gooky internal part keeping the water form draining from the main "barrel".
  • 15,935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa !!
Posted on Nov 10, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Code f21 keeps coming up and i have to keep wating a long time and when its done i have to put on drain and spin
The F21 means long drain and thats exactly what your experiencing. It is taking along time to drain because something is stuck in the pump filter screen,here is what to do to clean the filter screenoldtech2332_38.jpgoldtech2332_39.jpgStart by unscrewing that just a little and use towel/tupperware tubs and catch the water that will come out. Once all the water is out remove completly and check for a blockage
I hope i have been able to help you fix your washer,
Gene
Aug 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is F-21?
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps... Please post back if you need more information.
Daniel
Jan 02, 2011 | Kenmore HE2 Plus Front Load Washer
What does F21 mean on the digital screen?
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
Keeps on coding F21 - we have adjusted the hose several times but still seems to be giving us problems
Hi
Daniel
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
My washer displays the f21 error code. it did this once before and i had to take the bottom front panel door off to get to a the problem . i can not remember how to get this panel off. can you please...
Hi
Daniel
Dec 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I KEEP GETTING A F21 CODE AFTER EVERY CYCLE
F21 is:
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21 on Whirlpool front load duet washer
"F21" is a Long Drain error code. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
In most cases this is simply caused by a clogged drain pump and all that is required is a good cleaning. Read through the instructions provided in the link on how to do this. Make sure the washer is unplugged while servicing any of the internal components.
If the problem persists, you may have a drain pump that is malfunctioning or is damaged. The manufacturer recommends replacing the pump if this is the case.
Let me know if you have any questions. I hope this helps you.
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F21 Drain Problem with empty washer
Please see what I (royale) have done with my problem.
May 06, 2007 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
107 people viewed this question
Sal De
Marvin
Marvin
jimorris77
