Fgtrp gft5I have a compax presario new computer but the dvd droor won't open I trried the paper clip and it didn't work. and now my computer dosn't recoinse my dvd drive or the unit ir's self ther is no e drive. I just installed a network wireless adapter I may have puled some conection fro the drive it's self ahd thje white plug should it be connected to the usb 1 or 2 Thank you Jason
bluegreenash
  • 661 Answers
SOURCE: how to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem?
This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet.
something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection.
If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01
or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
Posted on Oct 17, 2007
yalmer
  • 552 Answers
SOURCE: dell truemobile 1300 wireless adapter
Here is a link to dell that will answer your question online.
http://support.dell.com/support/edocs/network/p60542/utility.htm
Posted on May 07, 2008
SOURCE: wireless adapter not showing up in network conections,icon
This happened to me when I had to install a wireless router in my house using my laptop to initialize the network for the first time.
The start up software messed with my settings for wireless detection on my laptop. It turned off the automatic detect for wireless networks in the
"Wireless Zero Configuration"
(This has the settings for the 802.11 wireless adapters
i.e. the one that comes with the R4000 presario)
to get to this hit start>run...
and type in this:
%SystemRoot%\system32\services.msc /s
go to "Wireless Zero Configuration" and enable automatic startup
, if the service is stopped, start it.
hit the apply button to save your settings.
Posted on May 21, 2008
Democritus
  • 120 Answers
SOURCE: Netgear WG111 USB Adapter won't work with service pack3 installed
http://kbserver.netgear.com/release_notes/D102534.asp
Reinstall the driver to the WG111 (after SP3 is installed).
Posted on Jan 28, 2009
tecnomage201
  • 221 Answers
SOURCE: My Wireless connection status page is blank
The AWL number was what I was looking for, thanx.
If the AirLink utility is running, there is where you would check the status. The way to set it so that the connection shows in the 'network connections '
Go into your Control Panel, then go into Network Connections
Right click on your AirLink wireless adapter and click “Properties”
Click on the “Wireless Networks” tab
Put a check in the box next to “Use Windows to configure my wireless network settings”
Click “OK”
If you wish to go back to using the AirLink101 802.11g Cardbus Utility, go back into the “Wireless Networks” tab in your AirLink adapter’s properties and remove the check mark next to “Use Windows to configure my wireless network settings”
Posted on Aug 04, 2009
DVD stuck in the DVD Player in this computer
Look on the dvd tray for a tiny hole. Straighten a paper clip and push it in the hole. You will need to push moderately since you'll be mechanically opening the drawer.
Aug 17, 2013 | Compaq Presario Dvd, Compact Disk Rw Ultra...
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Dvd drive won't open
Might have a stuck disc. Use a straightened paper clip in small pin hole of the CD drive to manually eject.
Nov 14, 2012 | HP Compaq Presario SR1920NX PC Desktop
Open CD drive
Your question is vague, but if your CD/DVD drive won't open you can try two things: Open your START menu and click on Computer. Find the CD/DVD drive under "Drives with removable storage". Right-click on it and select 'Eject'. If that fails, look on the side of the laptop where the CD opens. There is a very small hole into which you can stick the end of a paper clip you have bent for this purpose. Push the paper clip into the hole until you feel the latch release.
Sep 15, 2012 | Acer Aspire 3502WLCi Notebook
Does my compaq cq62-412nr have a webcam
I have the same model,thought I had the same problem,however..This model dosn't have a web cam.I called Compaq to find out how to open the cam,and that's when I learned it didn't have one.
May 17, 2012 | HEWLETT-PACKARD Compaq Presario CQ62412NR...
The button on my DVD driver sticks or won't
You can find a new one on Amazon or Ebay for less than $40.00. But if you look very closely at the cd or dvd drive there should be a small hole that a paperclip will go in. Push the paper clip in about 1/2 inch and the drive should release and open. If not a replacement may be necessacery. YOU can actually find a Youtube video to show you how. Very Easy.
Jul 22, 2011 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
It just won´t open, i think is something mechanical because when i insert a paper clip in the eject hole y doesn´t open either. Help please, how to fix it. Thanks in advance
I would turn the computer off the try a paper clip. You may need to "feel" up or down to find the ejector too (or press a bit further). Or, lift up gently on the drive door when you try to open it.
Oct 18, 2010 | Sony DW-G120A DVD RW Dual Layer Burner
Compaq presario c700
If there is a little pin hole on the front use an unwound paper-clip. push it into the hole and the mechanism should release? Realy need more detail though.
Apr 01, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Cd droor will not open
WITH THE POWER OFF, look on the CD door, you'll see a very small hole, unbend a paper clip, insert it straight into the hole, push until the door starts to slide open. This is assuming this is a computer.. If it's a CD player (stero-type), it MAY have this same hole. Again, power has to be off. TJ
Aug 18, 2009 | Audio Players & Recorders
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
