Question about Dayton (3E386) Heater
Just filled my propane tank, tryed to light the pilot light, it would light but was very weak and would not stay on. Is the pilot plugged and how do I fix? Thanks
  • Dayton Master
  • 3,416 Answers
Undo pilot tube at base of pilot and remove jet inside and clean or blow in pilot jet with tube or can of air should work then
Posted on Nov 10, 2010
Furnace goes out when blower should start
There is a sensor called a pressure switch that is attached to the area of the blower motor for the exhaust fan. It is bad or plugged.
Nov 16, 2015 | Heating & Cooling
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Coleman heater model 5445c700 propane camp heater wont light. It did work fine. When I hold the knob in the light position you can hear gas but it barely ignites then goes out. I've tried new gas and...
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Feb 07, 2011 | Coleman Heating & Cooling
My refilled 60 # propane tank leaked and then stopped flowing.
Rick, if the tank is normally plumbed for a horizontal position, and you have it standing vertically, then you are feeding liquid propane to your pilot light, hence the frosted hose etc., and a tendency for the pilot light to go out as it has too rich of a fuel to burn. There should be no vent to allow air in as propane is pressurized, and only attains zero pressure at 40 below zero farenheit. The valve you speak of should have been the liquid vent valve which is used during filling only, and is closed during any other use. Your supply valve should be in the wide open position. The pressure relief valve is only operational when the tank has been overfilled or overheated. You should have a pressure regulator between the tank and the appliance you are trying operate. Hope this helped. Marvin
Jan 04, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Gas dryer on, won't heat, just had propane delivery,tanks were em
I hope you didnt blow up by now, but your to hold a pilot valve down while igniting it
and keep down for 1 minute then release then turn valve to keep the pilot to operate the valve
Jun 18, 2009 | GE DBXR463GB Gas Dryer
Pilot wont stay lite
You either have a bad thermocouple or you need to reset the burner control.
Jan 29, 2009 | Coleman Propane Forced Air Heater...
Dayton (3E386) Heater Logo
172 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
