Question about Samsung SyncMaster 920NW Monitor
How do you open the case on a Samsun 920nw monitor?
  • 11,361 Answers
Service manuals: http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=920&kategoria=monitor&kat2=schematics
Use thin flat blade screw driver to crack it open at the bottom edge and work your way around, just be careful with the ribbon cable attched to the front bezel.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 10, 2010
Monitor keep blinking and switch on and off
The problem is in the power supply board, caused by one or more open capacitors, and in some cases develope a bulge at the top making it easier to spot.
Apr 19, 2012 | Samsung SyncMaster 920NW Monitor
What causes my Samsung 920NW LCD monitor to go dark after a few seconds? I am running windows vista home premium. Thanks
If the power indicator remains on, the problem lies in the inverter board that powers the back lights. The cause is usually bad capacitors that sometimes bulge showing they are open. the board needs to be replaced or an attempt made to repair the old one.
Feb 16, 2011 | Samsung SyncMaster 920NW Monitor
My monitor syncmaster 920nw hissing with power and diod not shine
I will suggest not to plug this monitor into the AC outlet until you open it up and inspect the inside before more damages are done.
First palce to look will be he capacitors in the power supply, look for bad caps with bulging top/seal or leaking, burnt parts, loose connection, etc.
See example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Samsung SyncMaster 920NW Monitor
My monitor syncmaster 920nw hissing when is power on and diod not shine
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Flashing power button on Samsung SyncMaster 920NW
Yes, More than likely the problem with the unit is blown capacitors on the power supply board, the flashing power light is a good indicator of this type of failure. Here is a link to a repair guide with pictures and videos showing how to open the unit and what to look for and replace to get it back going again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Feb 12, 2010 | Samsung SyncMaster 920NW Monitor
Samsung 920nw when it warms display disappears & a few
Most common cause of the failed monitors are bad caps in the power supply, if it is about two years old, I would open it up and look for bad caps first, then look for any burnt parts, post back so we can guide you further, see failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Samsung SyncMaster 920NW Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Pink color
check the led back light of your monitor. I you cant do-it-yourself better to go to service center
Jul 30, 2009 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920NW Monitor Logo
201 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
