Question about Dryers
Kenmore dryer spins, but no heat. cleaned out lint and started again. it got warm for a while then just spun without heat
  • 550 Answers
Image sample may not be identical but will be close
kenmore dryer spins, but no - 86ac2e0.jpg The most common cause for no heat is a blown therma fuse. If you cleaned a lot of lint out there may have been sufficient air restriction to overheat and pop the fuse. It is not resettable, but in NS costs around $8.00.
Remove the plug
remove the rear cover
trace the exhaust air lines untill you find something that looks like the image above, its about the diameter of a quarter. There are often 2
remove the two wires,
test- with a multimeter 0 resisttance=good infinity resistance = bad
- with a battery and bulb, lights = good, dark = bad
If fails test, unscrew two retaining screws, take the thermal fuse to your local dealer and buy one of the same type,
Dealer will have them there are only about 5 kinds for every dryer made.
screw in, reinstall wires, reinstall back, plug in, Dry
Posted on Jun 17, 2008
Kenmore 77904 doesn't heat
Check the lint build up inside the exhaust vents first and try again
May 09, 2010 | Kenmore 73952 Gas Dryer
Our dryer stopped heating so we changed element and cutoff kit, worked for 2 loads and quit, again changed cutoff kit and worked for 15 minutes and stopped heating again, what are we not doing right?
The cutoff is there to trip if too much heat builds up around the heating element. The most common reason for this is plugged venting. But it has to do with poor air flow for sure.
- Check to make sure your lint screen is clean and nothing is fallen down the lint filter chute
- Briefly run the dryer without the vent connected and feel the air coming out the back of the dryer, it should feel like good air flow, now connect it again and feel the air where it comes out of your home, it should feel about the same strength.
- To clean the vent, you can use a long brush, a vacuum or even a leaf blower to try and clear the lint. (blow from inside out or you may make a mess inside)
Apr 23, 2010 | Kenmore 62802 Electric Dryer
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Kenmore model # 110.22632.100 does not spin real fast inspin cycl
turn dryer on & make sure that the drum on your dryer is spinning, this could be a belt issue going bad or if the drum is not spinning the belt has broke. It also could be the lint system needs to pulled appart and cleaned out with a chop vac. It could also be exhaust tube kinked behind the machine.
Jul 02, 2009 | Kenmore 23012 Top Load Washer
My Kenmore Series 400 dryer spins & heats, but the clothes stay wet. I've cleaned the lint basket & have checked the vent from dryer to outside. Any suggestions?
Check the outside vent again while the dryer is running. There should be a good strong air flow, if not then your problem is in the exhaust system somewhere
Jun 21, 2009 | Kenmore 73952 Gas Dryer
Roper dryer res7745pq is taking 2 cycles to dry and vent is clean?
check if the thermostats in rear part of dryer are covered with lint. take power off to dryer and remove back panel you will see 2 or 3 thermostats if there is a lot of lint around them carefully remove lint. if that doesn't solve problem make sure clothes are coming out of washer spun dry enough .. check lint screen on dryer. is the vent clear all the way outside ?, in winter little critters like to set up housekeeping in vents where the temperature warms them up. you can also check if heat is cycling open door to dryer and press the door button, start dryer and observe heater , it will come on then shut down and it should come back on in a minute or two, if it doesn't come back on the cycling thermostat may be at fault
Jan 26, 2009 | Dryers
Kenmore dryer starts, then stops. Heated motor smell
First CLEAN out the lint, not just in the mesh screen, but also by opening up the dryer to check for lint around the motor, and the manifold that connects from the drum to the outlet tube. Open up the manifold, carefully, remove lint, and REPLACE the heat sensor/temperature thermocouple that is on the outside, and has a protruding point into the manifold ($20 or less). If the drum spins when you start the cycle, it is NOT the motor! The burning smell is probably LINT that stuffed into the outlet pipe and manifold.
I have cleaned the outlet tube, manifold, and areas under/around the drum for my dryer, and my rental properties and "fixed" the problem. If it still turns off, then get the correct replacement sensors and replace them. DO NOT open the heating element. The wires inside are fragile.
Sep 08, 2017 | Dryers
My Kenmore Elite dryer spins with no heat
please check the thermal cutoff. these are the parts with 2 thick wires attached to it. they are normally located near the heating element ( if electrical ) and (near the exhaust if it is gas).
these parts control the heating element.
tnx 4 using fixya,
drcool
Nov 05, 2008 | Kenmore 73952 Gas Dryer
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
