Question about Amana 3.2 cu. ft. Top-Load Washer
Washer will fill up with water and just stay in the same place even though it starts up and seems like it is washing. I can change to another cycle and sometimes it works. eventually it will spin out the water. Machine is 10 yrs old. Amana LW-2302-W Is it bad enough to just replace?
  • 33 Answers
Your timer is getting weak you might get one at a good price it depends on were you live
Posted on Nov 10, 2010
What can cause a washer to not fill with cold water during the wash cycle?
well it would seem these are the possibilities:
1. cold water not turned on
2. hose kinked
3. inlet valves not working
4. wiring issue
5. control board issue
oh and plugged inlet fill filter
good luck
Sep 02, 2015 | LG Washing Machines
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Kenmore Elite (Model # 110 23032101) won't fill with water, even though the inlet valve has been changed and the hot/cold water lines are working fine. The screens have be checked and look clear. The...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23032101&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The most likely culprits are the Water Level or Water Temperature switches.
The Service Manual has procedures for testing each of them.
See the following for how to gain access to the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Apr 16, 2010 | Kenmore Washing Machines
The washer doesn't always fill up when we turn it on
Hi, Dose the water fill the first time you start it but, then will not fill in the rinse cycle? Does the water continually try to fill but never gets to the top?
I want to help.
Thanks
Vic
May 12, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
347 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
