Question about Whirlpool Duet GHW9150P Front Load Washer
SUDS error message appears, machine starts to drain, F35 error message flashes then nothing. I've unplugged it, tried to restart it, have not used non-He soap or too much soap...unit is about 12 months old. Thanks! Lara
  • 15,935 Answers
The "SUDS" or "SUD" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) - 0 ohms
Pins 3 to 4 (Overflow) - 0 ohms
Pins 4 to 5 (L1) - 0 ohms
Pins 4 to 6 (Empty) - 0 ohms
Thanks for using FixYa!!
Posted on Nov 10, 2010
Whirlpool duet f35 error-suds error
Maybe this will help, but I'm not sure
Condition:
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Check:
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check Drain Pump
Check Pressure Switch
Check CCU
Dado
Sep 13, 2015 | Whirlpool Washing Machines
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wfw9600ta01 with the common "suds/F35" error code. Yes......we've been using the right soap. suds starts one minute into cycle followed by the F35 code immediately after the suds cycle...
WARNING: THIS WRITE-UP IS COMPLETELY MY OPINION BASED ON MY EXPERIMENTATION WITH THE EQUIPMENT. TRY ANY OF IT AT YOUR OWN RISK. YOU WILL BE SOLELY RESPONSIBLE FOR ALL THE CONSEQUENCES (GOOD OR BAD EITHER WAY) THAT YOU MAY REAP FROM THE MACHINE YOU WORK ON.
I made the biggest mistake of taking the whirpool WFW9600TA01 from US to India - I had been totally frustrated with the SUDS/F35 issue, absolutely as explained in the question above.
I started as a novice but feel very confident to write this solution now. There are several areas that could cause this problem. Fundamentally, as the water fills the tub, the pressure form the pressure switch is sensed. If the value is not in line with what is programmed, you get this error. This deviation in pressure value can be caused by any of the below reasons.
First and foremost thing I would do is remove (disassemble - note very carefully the assembly and the position before disassembling. You will need to reassemble in the exact same way in the exact same position) and clean all the pipes, hoses and connectors
Details:
The problem could occur because of:
1. True suds formation due to wrong soap usage (pretty often the problem) - Solution for this? - use a lot of vinegar and a few "risnse and spin" cycles with out any clothes in the washer
2. The pressure switch could have gone bad. Solution - replace the pressure switch (I would do this the last though)
3. There could be dirt collected at the water inlet. Solution remove the water inlet and clean the cup shaped strainer
4. Your outlet/drain pump (the one that pumps the water out of the washer into the drain) may have worn out, there by not draining out all the water. This will leave residual water impacting the next run. Solution replace the pump assembly
5. There may be particle collection such as coins pens, small pins etc in the darn pump inlet strainer causing the drain pump to not work properly and in turn causing SUDS/F35. Solution - remove the front of the drain pump inlet and remove the particles and restart.
6. There is a conical shaped connector connecting the outlet of the tub to the inlet of the drain pump. At one side of this connector (the broader side connecting to the tub) there is a plastic ball in it. If the ball is punctured, water may have collected in it causing it to weigh more than what it is supposed to. When the drain pump runs, the weight of this ball may counter act to not allow proper draining of the water. This residual accumulation of the water will cause SUDS/F35 in the next cycle. Solution - replace that flexible connector. Atleast drain the water from the front at the drain pump inlet, if you want the washer to work for that cycle.
7. There is a small white plastic tube at the back which runs a black tube to the pressure swtich. The assembly is pretty interesting. It is a simple insertion with the air tightness being achieved by a simple rubber gasket covering the insertable part (do not know why the design is such). After a few washes due to the vibration generated by the tub during wash, this gasket can move causing air leaks. Such air leaks do not cause any issue to the current run, but will result in a SUDS/F35 in the next run. It will remain so for al the next runs unless it is re-inserted properly. Solution for this? every time open the rear and make sure the plastic white part is pushed in well.
8. There are other reasons like the main control circulatory / mother board could have gone bad etc. You can figure if this is the problem by running the diagnostic tests for the most part - there is a good chance that only a certified technician can tell you. Solution - replace the mother board (quite stupid huh!!)
9. Finally, the steamer assembly could have gone bad - Although the manual says this, I cannot quite figure out how this would affect the pressure buildup in the tub - I do not know what to do. More than likely if you invite a technician, the person might ask you to replace this assembly.
Try everything - the net effect should be that you have plugged all air leaks. I know some expect to see water leaks at place where air leak exists. That may not be true at all. Good luck with everything.
Jul 06, 2010 | Washing Machines
Error f35? What's the fix?
They can and fixed my washer today! The fix was the replacement of a switch. The item # was W10156252 for my washer. It is called a switch-WL. Item # may be different for your model. I was getting SUDS and F35 errors. To install it you just remove the top part of the washer and should be located at the upper right-hand side, attached to a black hose. The switch has a small computer board. The price of the swith is around $130. Fortunately I bought a 3-year warranty on my washer.
Apr 18, 2010 | Kenmore Elite HE5t Washer
I start the machine the suds flashes then it goes away and the F35 flashes and nothing happends I tried to use the clean washer cycle and it still comes up F35 then when I try to push the cancel button the...
If this is a steam unit you have a bad analog pressure switch,has been a common issue in those units,Gives an F35 core and sometimes a SUD code.
Sep 20, 2009 | Washing Machines
My Kenmore Elite HE5t washer flashes SUD continually, then goes to F35 mode and shuts off. Help!
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Aug 02, 2009 | Kenmore Washing Machines
F35 and Suds error on Kenmore Elite HE5t
I also got the SUDS error followed by F35 many times. I replaced the analog water level switch, Wirlpool part number W10156252, and the problem went away. The part is located against the back right corner of the top of the washer after removing the top cover. The part cost $62.99 + $12.95 express shipping from ApplianceZone.net. I have the Kenmore HE3t Steam Washer, model number 110.46752 700 front loader. I was able to run about 6 loads of laundry by unplugging the washer, waiting about 5 minutes, the re-plugging and re-starting the washer. Thereafter, the problem became permanent. I always used HE detergent. The washer was purchased new in December 2007, and the I made the repair in September 2009. I spent about $1300 for the Kenmore H3t Steam Washer, and I am disappointed that it required repair after less than 2 years. My mothers old Maytag washer lasted more than 15 years, and was not susceptible to soap SUDS.
Jul 20, 2009 | Kenmore Elite 45986 Front Load Washer
When we try to start Washing machine (Kenmore Front Loader) A code F 35 or Sud pops up And flashes.
Apparently this problem "Suds" and "F35" error codes is happening to a lot of people ~ If you do not have any clogged hoses, then the Analog Pressure Switch is more than likely the issue.
Here's the downside, the problem is so wide spread that the part is back ordered for weeks. You would think that SEARS Extended Warranty Service would keep this part in stock so their customers are not without a brand new washer for over a month!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
F35 Message on Brand New Washer
suds is determined using the level sw located on top right rear side. remove top cover to see. most letter codes do convert to a f code. most common reason for suds error is use of standard detergent or too much detergent. running a empty load of fabric softener can clean the system. or rinse/spin with nothing. other common problem is this is a whirlpool product.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
