Question about Maytag MAH8700A Front Load Washer
New Maytag front load machine. 2" drain, keep getting a backup of water. Someone said pipe needs to be 3". Help
  • 33 Answers
3" wouldnt hurt but that shouldnt be why get the pipe snaked out first just incase something is cloging the pipe
Posted on Nov 10, 2010
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
"nf" error code on Maytag front load stackable
I think your hunch is probably correct. "nf" is "no fill" or "slow fill" so if the machine is in a cold enough location it likely has frozen supply lines or inlet water valve. About all you can do is slowly warm the area around it with a space heater or wait until Spring. I wouldn't try to warm it in a day though. Frozen pipes that are thawed too quickly can break, leaving you with a real mess on your hands, possibly even structural damage to the property. All you need to do is get the temps above freezing, it doesn't need to be balmy. If you use an electric heater make sure it is well away from combustibles and the machine if possible. When water lines break they tend to spray where they want so keep that under consideration when placing the heater and make sure it's off the floor. If i started warming the room today i wouldn't even try to use the machine for a week. And i'd babysit it as much as humanly possible. Good luck.
Jan 24, 2013 | Maytag Washing Machines
Hi, Bought a Maytag front loading washer #MAH6500AWW about 5 years ago. 1. The amount of water remaining in the machine (if you turn the drum it sounds like SEVERAL gallons of water swooshing around)...
i would say the drain pump is blocked.......... you could take the drain hose and leave open end at lowest point on the floor into a container and let water drain out..........easier if you can get machine to outside door and let water drain outside i did a zanusi last night...stuck in the pump was 9 small coins 1 hair grip and a womans bra under wire............
follow the waste hose at the back of the machine it ends at the pump......... open the pump then check it out...
good luck..
cheers
Apr 04, 2011 | Washing Machines
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Nov 20, 2009 | Maytag SAV5710 Top Load Washer
The door won't lock and water is leaking out
it may be being sucked out by siphoning through your sewer pipe .Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot , and get a siphon break . When a washer fills , but water level doesn't rise in the machine ,
Aug 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain or spin.
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Check out your pump too, right after the filter for any block.
Apr 05, 2009 | Tecnik TKL9260 Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Jan 06, 2009 | Maytag Legacy Series Top Load Washer
Washer takes in water and immediately drains it out
See that there is enought pressure from your inlet pipe into the machine, maybe someone closed the wall valve. Plug off the wall socket. Check the filters on both sides of this pipe, clean out. Also clean the inlet into machine.
You said the washer will not fill, but is it coming in, the water that is. If this is the case, your outlet pipe from the bottom of the machine is at the wrong height, it should be at about 3 feet above the ground level; your pump pumps this waste water OVER this height. Check these out.
Nov 25, 2007 | Maytag MAH2400A Front Load Washer
Maytag MAH8700A Front Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
