Question about HP LaserJet 6L Printer
MY PRINTER PRINTS BAD EVEN THOUGH I INSTALLED A NEW PRINT CARTRIDGE. IS THERE SOME WAY TO CLEAN THE "HEADS"?
    Problem Solver:
  • 11 Answers
My Brother 465CN recently decided that even though I have a new black ink cartridge in, that there is no cartridge.
The code is within the ink cartridge itself. If it is not a main brand cartarage, you may have th esame problem with both . I would suggest buying a main brand one .
heads can be cleaned with a tooth brush and alcohol. Dry well.
www.brother-usa.com
Jun 29, 2014 | Brother MFC-465CN InkJet Printer
My hp 825 prints "blanks" even though cartirdges
Troubles with the connection or power supply could be another issue causing failure to print in your printer. If there is any loose connection or error in the cables or connection, your printer might fail to work at all. The problem might be easily averted if you are checking the connection and ensuring that all the connection are intact. You might disconnect the cables and reconnect them, to ensure that they are intact.
Jan 18, 2011 | HP DeskJet 825c InkJet Printer
Even though I replaced the printer cartridges just a little while ago my printer only prints pink and some black?
if the printer has not been used for a while try using the cartridge clean function button on your printer.
this will clean the print heads and should resolve the problem.
if persists suspect cartridges need replacement.
I hope this was useful.
Jan 11, 2011 | HP DeskJet 895cse InkJet Printer
Our daughter has an Epsom PaperMate 240 printer. Until now we have used only Epson cartridges but last time we bought a compatible cartridge. It ran 4 prints then the "out of ink" message was...
Hi
First it is not advisable to use other catridge other than epson because it will damage your printer. Because the printer have specialized chip that detect epson cartridge only. It will be okay for 2-3 times but later on it will say out of ink even you put new cartridge. I suggest if your printer had reset ink cartridge, just reset it and turn off your printer and computer for 5 mins. Then to restart on fresh mode and then try to print again. Next time use epson only because later it will not detect ink cartridge any more.
I hope it helps you.
Jan 11, 2011 | Office Equipment & Supplies
Fading prints and new cartridge error, will not aliegn
It's possible it is the new cartridge, but it sounds more like the print heads. I had the same printer and same problems until I changed the print heads. You are better off buying American Made Printer Ink Cartridges Even If They Cost A Little Less Than Name Brands. I get mine from www.officeinks.com with a 1 year quality and satisfaction guarantee with free return shipping. I have used it once and had no hassle.
Oct 16, 2009 | HP Officejet 5610 All-In-One InkJet...
HP all-in-one not printing cyan color
Place a soft clean tissue paper over the cartridge print head and leave for about eight minutes. You can secure it with the aid of a rubber band. It should be held firm ok. If the tissue paper is not dampened by ink then the cartridge would have gone bad or the ink dried. You also know that they have expiry date and could go bad while yet in the packaging b/c it has expired. Good luck
Jun 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
New tri-color ink cartridge prints only red
Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
Sep 09, 2017 | HP OfficeJet t65 All-In-One InkJet Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
New black installed; will not print in black ink. Everything else prints!
hi, it is possible that the black cart was not installed properly. Try reseating the black cart and see if it works. You can also try to calibrate the printer. you can do this by pressing the menu button then go down to calibrate printer. after that it would also help to perform a deep clean which can also be found on that same menu. then try to print. If all these fails, try to call the kodak hotline 800.421.6699
Oct 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer doesn't print even with new ink cartridges.
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
DO THIS AS FINAL REFUGE
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
Mar 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
HP LaserJet 6L Printer Logo
41 people viewed this question
Clive
Clive
