Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LE error code, bell ringing - LG LDF6810ST Stainless Steel Built-in Dishwasher
Not an expert, but we paid $60 for the repair man to come out and just run his hand along the touch pad on the door. It stopped the error code and the bell ringing noise! I wish they would have mentioned that over the phone and I could have saved $60!
Posted on Nov 16, 2010
Where is the torque converter clutch relay (code P-0750) located?
Torque converter is inside of the bell housing on the transmission
Aug 25, 2014 | 2005 Toyota Corolla LE
New Hall Sensor & Rotor and code LE with some ringing noise
The LE code is displayed when the motor goes into an overload situation, if you have changed the Hall sensor and rotor, the only other problem is the stator overheating which will bring on the LE display.
Check the stator assembly, replace is faulty.
Dec 18, 2013 | LG WM2801HWA 4.5 cu. ft. Front Load Steam...
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
What does error code LE mean?
heatman101
Sep 20, 2010 | LG Washing Machines
Machine starts cycle shortly into the cycle stops LE shows in win
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in thsi case, the motor will need to be replaced.
Oct 16, 2009 | LG Washing Machines
Le code on ldf6810bb lg dishwasher
The LE error code can mean that the impeller is damaged or there is some debris blocking the the sump area underneath the filter or the wash motor has failed. In that order.
Remove the spray arm and filter (9 phillips screws) - inspect impeller for damage, with flashlight, look everywhere for debris (watch out for broken glass!) Reassemble and test.
If problems continue, schedule as service call focused on the wash pump/motor.
Good Luck!
Apr 06, 2009 | LG LDF6810 Built-in Dishwasher
LG TROMM DRYER DLE2514W
Hello Napew65,
Please use this link http://136.166.4.200/contents/Laundry/DLE2514W.htm to get access to the service, operator and all manuals associated with your dryer. You can run diagnostics as shown in the service manual to interpret the root cause of your problem. Let me know if you still aren't able to get this resolved.
Regards
Rick
Jan 04, 2009 | LG DLE2514 Electric Dryer
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Code LE comes on my washer it is a LG wm2075cw
Symptom Error Codes
Answer LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 17, 2008 | LG Washing Machines
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
330 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
