Question about RIM BlackBerry? Tour 9630 Smartphone
My blackberry tour is fully charged. Every once in a while it shuts itself off and when it loads back up, it says 20% battery left. then it shuts off again,and doesn't turn back on until i plug it into the charger, what can i do to stop it from doing that?
  • 903 Answers
It sounds like you have a bad battery. Does it work okay when plugged into AC power? If so, your battery is probably dying and needs to be replaced.
Posted on Dec 22, 2010
Tip
How to uninstall apps on a BlackBerry Tour
Uninstalling an application from a BlackBerry Tour is a simple process that only takes a few minutes. First, find the app's icon. (By default, this icon will be located in the Downloads folder unless you've moved it.) Move the trackball over the icon and press the BlackBerry button (the one with seven dots to the left of the trackball). From the menu, select <span style="font-style: italic;">Delete</span>.<br /><br />A confirmation window will appear asking if you're sure you want to delete the program. Select <span style="font-style: italic;">Delete</span> again. You'll see a message that says, "Deletion will occur when handheld is restarted," and you'll be prompted to reboot your BlackBerry. If you choose <span style="font-style: italic;">Yes</span>, the phone will shut off and go through the cold boot process -- just like if you'd pulled out the battery. It may take several minutes for the device to fully boot back up, but when it does, the application will be deleted.<br /><br />If you choose not to restart at that time, the application's icon will be removed from the folder, but the application itself will remain on your BlackBerry until you perform a cold boot (turn the BlackBerry off, pull out the battery, then reinstall it and turn the phone back on).<br /><br />Even after you've completed the uninstall process, the application's files will still remain stored on your BlackBerry. You can find and delete these files by navigating through the BlackBerry's file system. In your Home folder, select <span style="font-style: italic;">Media</span> and then press the BlackBerry button. Choose <span style="font-style: italic;">Explore</span>, and you'll see two options: <span style="font-style: italic;">Media Card</span> and <span style="font-style: italic;">Device Memory</span>. Select <span style="font-style: italic;">Media Card</span>, then continue down the folder tree by selecting <span style="font-style: italic;">BlackBerry</span>, then <span style="font-style: italic;">app_world</span>, then <span style="font-style: italic;">downloads</span>.<br /><br />The next folder will have a name that's a combination of letters and numbers, which is your BlackBerry's PIN. Select this folder, and you'll see a subfolder with the name of the application you just deleted. (If you have more applications installed, there will be folders with their names here as well.) Press the BlackBerry button and choose <span style="font-style: italic;">Delete</span> to get rid of the folder, which is only taking up space and isn't necessary anymore since you've already uninstalled the application. If there are other applications here that you've previously deleted, you can erase their files too to free up more space.
on Dec 22, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Blackberry tour for Verizon keeps resetting. Scre...
The battery may be a little loose in its setting. Turn the phone off and remove the back cover. Take the battery out and reinstall it, making sure it sits snugly and it can't wiggle around at all. (While you have it out, blow some compressed air onto the contacts if you have any.)
The phone will go through its initialization when you turn it back on, but after that if it still does the same thing, see if it does it when you're connected to AC power (through the battery charger). If it doesn't happen when the battery is charging, you probably just have a bad battery.
May 19, 2010 | RIM BlackBerry? Tour 9630 Smartphone
My blackberry tour was charging and won't power up?
First charge your mobile for atleast 1 hour,and switch it ON you have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device
If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry through desktop manager. Or else please visit the nearest service centre
Nov 03, 2009 | RIM BlackBerry? Tour 9630 Smartphone
My blackberry 8310 just shut off and won't come back on.
Take the batter out, leave it out for 5 minutres and do a hard reset to it. Once the batter is put back in it should first turn on with a red light and eventually boot up if you say the bvattery is fully charged
Aug 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry storm wont turn on or charge red light blinks constantly is there a physical reset button
This may work. Mine was doing the same thing this morning so I was looking through forums to no avail.
I have been using my USB charger since I got my Storm as I left my wall charger in another city and only just got it back...
The phone would do the same thing when I tried to charge (off USB) depsite pulling out battery etc.
I went home and plugged into wall charger and left it (maybe 20 minutes?) and a battery with a lightning bolt followed by the loading page and it is now back to life...
Hope this works out for you!!
Jun 09, 2009 | RIM BlackBerry Storm 9530 Smartphone
My NEW Blackberry 8310 won't charge! Red light flashes just once.
get a message saying my USB is not sufficient enough to charge phone ???? It works on other computers just not the one I need it to work on.
May 09, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Phone turns off every couple minutes and then turns on by itself.
What I would do is turn it off completelly for a few minutes. take out the battery and let it cool down for a few minutes. If you have a battery that if fully charged put it back in and turn on your phone. if your battery is not totally charged, charge it. A phone whose battery is not fully charged may cause your phone to flip out. sometimes it's also water damage to the phone that causes it to turn off on its own.
Water damage happends from body heat, from taking it to the bathroom when you're in the shower, or from putting it directly in water.
Hope this helps.
Mar 25, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
RIM BlackBerry? Tour 9630 Smartphone Logo
53 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
