Question about GE Kitchen Ranges
I just spilled water on my glass-top GE profile range and it sparked, sent out a few flames and now it is making a constant buzzing sound. What should I do? Thank you!
  • 33 Answers
Un plug it and let it dry then call a tech you just burned the bord up soory
Posted on Nov 10, 2010
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
After cleaning my stove there is constant clicking
The igniters got wet. Try drying them out with a hair dryer or shutoff the breaker for a few hours.
Jun 23, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE Profile JPG636 cooktop has an ignitor problem. It clicks constantly, and all the ignitors on all 5 burners are 'going off'. It happens every 8 or 10 seconds whether we're cooking or not. If anyone...
The most common cause for this issue is from liquid getting into the ignition system for the range. If someone has spilled water or other liquids into the burner knobs or the ignition system it will cause an electrical short in the system causing the igniters to come on constantly when the knobs are off. The fix to this is to unplug the range and wait 24 hours for the liquids to dry up. You can speed up this process with a hair dryer pointed at the burner stems(knobs removed). Once the liquids have dried up the problem should stop. I would not leave it plugged in until then because the ignition system could be damaged from the constant sparking.
Feb 23, 2010 | GE Profile JGP636 Gas Cooktop
I didn't spill water i just cleaned the range top
they should stop onnce they dry out, if not you have managed to short out the spark module
this should be replaced by a service tech
Oct 02, 2009 | GE JGBP28 Gas Kitchen Range
Stove top burners won't light.
Susan, there is no pilot flame on the Spectra models of ranges. However, the possibility that the electronic ignitors have gotten soaked and are shorting out is quite likely.
You should disconnect the power to the oven and remove the burner grates, burner caps, and the burner assembly cores to expose the ignitor posts. Check to see if there is any remaining water there and clean off and dry the ignitors and burners completely, as they might have something on them causing them to short out against the stove top, rather than spark properly, as they should.
Once you've cleaned and replaced the stove top parts, restore power and try to light each burner, one at a time. If none of them spark or light, then you need to check to make sure you haven't tripped a breaker for the stove or a GFCI outlet that the outlet that the stove might be plugged into, somewhere in the Kitchen.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
Buzzing Noise coming from GE Stovetop.
It could be a loose transformer that needs to be remounted. Pull the stove out, remove all of the screws at the top and visually inspect the transformers and wiring. This should be an easy fix, but if you leave it too long then your stove will malfunction. I hope this helps at least get you to the next step.
Jun 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
107 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
