Question about Peg Perego John Deere Gator HPX Ride on Toy
The gator goes then stops for a few seconds then starts back up. Battery is brand new and fully charged. What could it be???
    Genius:
  • Peg Perego Master
  • 1,508 Answers
I think you have a bad motor, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
3 Suggested Answers
  • 16 Answers
SOURCE: How long to fully charge the battery
It takes 8 to 12 hours for a charge. I leave ours in for 24 and it seems to last a little longer. You might need to purchase a new battery which you can get at Walmart by the power toys. They usually run about $40, hope this helps.
Posted on Jan 29, 2009
Samir3050
  • 70 Answers
SOURCE: Our son's peg perego john deere gator stopped
It is most likely the Gearbox, it is easy to find and easy to replace. It is right under the gear shifter and is a "harness" with wires that will need replaced, if you call the tech support for Peg Perego they are very helpful and will get you on the right track. Your old battery is most likely fine, but keep it until you fix the gearbox switch. Afterward (when gator is again operational) I would imagine you could return the new battery since you really should not need it. Peg Perego support is 1800-728-2108 and you can also look for parts at www.mypegperegoparts.com
Posted on Mar 01, 2011
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
Bought new battery for the john deere gator ride on toy but only runs for a short time then battery needs recharging
Hi, How long does it run? Typically you should get at least 45 min of run time out a fully charged battery. If it's slowing gradually and dying in just a few minutes its the battery. If it's goign full speed and then stopping suddenly, it's probably the thermal breaker located in the shift mechanism.
Aug 25, 2014 | Peg Perego John Deere Gator HPX Ride on...
My gator just stopped can't get it to do anything
power goes from battery to foot pedal, then to shifter, then to motors. I'd check the shifter switch and make sure that its connected securely, if it is then disconnect one of the rear motors and try again, then reconnect and then disconnect the other rear motor and try again. If the problem goes away with one of the rear motors disconnected then that motor was your problem
Jun 12, 2014 | Peg Perego John Deere Gator HPX Ride on...
Peg pergo John Deere Gator goes for about 2 seconds then stops suddenly
it almost sounds like a thermal fuse, but these don't have a thermal fuse, so id say it might be a bad shifter switch
Dec 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
I have a Canon G5 and am on my third set of rechargeable batteries (I bought an extra Canon rechargeable battery when I purchased the camera and then 2 Canon brand replacement batteries when the first 2...
Thank you for such a detailed description, wishing others would take your lead. To the problem camera designated batteries (other then AA rechargeable) have always been a bit of a sore spot for me because the user is compelled to purchase a specific battery. As much as I prefer the name brand accessories for the camera there come a point where you just gotta venture forth with third party accessories. There is nothing wrong with using an "off" brand in fact what I've found is that is some cases they are a better battery. Again back to the problem. I grasping thoughts on how to word this but, here goes. As much as the manufactures would like you to believe that these batteries do not form a memory they do. Also the battery can trick you into thinking it's fully charged when in fact even though the charge light is saying completed it's only got about 1/3 charge. I've worked with Canon's BP 511 and now the "new" BP 511A for many years The BP511A or equivalent is the better battery. What needs to be done is to drain those batteries down until they stop, let it cool don't take it from the camera to the charger. Time the battery when you put it on the charger, meaning not to the second but what you would "normally" do is plug the battery into the charger and leave it right. Well what's possibly happening is that within ten minute the ready light is coming on, (something stupid going on in the battery) So check the battery stat of charge after say 15 minutes and if it says it ready (drum roll please) remove the battery unplug the charger for a few seconds and place the battery charger back onto the wall outlet and plug the battery back into the charger and look at your watch again. I've had to do this as much as three times until the thing would get the idea it was to take a charge "normally" about 2 hours will bring it back up. There is no device I've found to completely drain one of these batteries so over a period of time in your case one year the batteries begin this fit. I've since replaced the BP511 for the better BP511A's or equivalent. I'm not pointing a finger because myself and staff do the same thing and pull the battery before going to a shoot if it's showing partial discharge and the thing gets put onto charge and we start this cycle all over again. Be careful of the charger as well meaning don't just disconnect the battery and put it back on charge when it's going the cycle thing disconnect the charger from its power source as well because it holds a memory for a few seconds and will just shut off in a few moments if you don't.
Long story but I've been doing this now for 9 years since the dawn of Canon's 30D Cheers
Jan 16, 2011 | Canon PowerShot G5 Digital Camera
NDS Lite Turns on but then after a few seconds turns itself off
Check the battery is fully charged, its always worth fully charging a battery before you start soyou can route that out.
Check the cable is fully in for the bottem screen, if it is not in the ribbon connector all the or at an angle somtimes this can happen, while checking that you might as well check the other cables as well just incase. let me how it goes.
Jan 18, 2010 | Nintendo DS Lite
We just bought a new battery three weeks ago for the Peg Gator. It worked perfect up until now. It is going very slow and acting like the battery didn't charge Any suggestions? Could it be the battery...
this is a very common problem with these types of ride on toys, you have to make sure theres not to much weight in it or it will drain the battery almost right away, also the charger itself maynot be charging it fully . Try charging it fully, put the amount of weight you normally have in it and when it starts to slow down take out the child or children and reach in and push the gas pedal to see if it made a difference.
Mar 20, 2009 | Peg Perego John Deere Gator HPX Ride on...
Nokia 5300 black mobile
Take the phone back to the retailer you bought it from and demand a replacement or that they fix it VERY quickly. The phone is obviously defective from start.
My best guess is that they will fix it for free, at least thats what they are supposed to do.
Oct 13, 2007 | Nokia 5300 Grey Cellular Phone
Peg Perego John Deere Gator HPX Ride on Toy Logo
135 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
