Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
A screw that holds the shelfing up broke and a part is still inside can i drill trough that without damage to a water line? It is vertical plate screw
  • 33 Answers
Yes but be very carefull
Posted on Nov 10, 2010
Flavel milano e60 how to fit new fan oven element that is riveted
That is complete RUBBISH the screws are accessible from the rear of the oven. At the back remove the screws holding the plate and you will see the element housing. Remove the two screws and the spade connections. Get someone to hold the new element in place for you and attached the screws. Fiddly job so be patient. Connect the spade connections and replace all plates front and rear. Should be the job!!! Someone hold the element in the cooker whilst someone connects at the back. Whatever you do, DON'T TAKE A DRILL TO YOUR COOKER!!
Dec 13, 2012 | Ovens
Freezer is collecting ice in the bottom and don't know where it could be coming from. Where should I start. Some say there could be a clogged drain, but I don't see a drain in the bottom. Help!
If you remove all the ice from the freezer floor, pull the bottom bin out and look at the freezer wall there should be a trough with the drain in it. If you can't see the trough you'll need to take all the shelfs out and remove the back panel from the frezer. Once you do that you'll see an aluminum evaporator coil and below that you'll be able to see the trough and the drain hole. Remove the ice from the trough, located the drain hole and using a hair dryer, hot water, or a screw driver, clear the ice from the drain. If you use a screw driver be careful not to knock a hole in the line. Once water can flow freely down the drain your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 07, 2010 | Kenmore 57029 Side by Side Refrigerator
The key to my 05 Lacross does not have metal in the key ring hole and the plastic broke. How do I repair? can I drill a new hole without damaging the chip?
Hi, the only part that dont have the circuit under neath is the part that has broken off the only chance you might have of finding somewhere to drill through is if you take the key apart and have a look on the inside and see if their is a small gap you can drill through.
if you just drill through without taking the case off you will never know whats under neath, now with the case off you may find a small part near the back of the key next to the part that broke off but it will only be a small area, so if you take the case off and drill a hole you will probably need one of those straps that go through a mobile phone, you know the string type that you feed through the hole on a mobile well you may be able to drill a small hole big enough to put this string through, but you wont be able to drill a hole big enough to put the metal ring through on its own.
if you can get the case off without damaging it then have a look at the back part near to the part that broke and you should find a small area to drill through, please dont drill anything without taking the key fab apart as you will drill through the circuit, its not worth guessing as damaging this could mean your car wont start.
failing that replacing the key is the only option
take the case off and have a look first just take your time and try not to break anything inside the key, if you have messed about fixing things before then you should be able to take the case off the key.
let me know if you need further assistance ok
Aug 18, 2010 | Buick LaCrosse Cars & Trucks
How do you repair 2005 jeep liberty rear window hinge on the outside of the vechile
go to dealer buy a new hinge if screwsare broke or stripped see if dealer has a repair plate or make one your self a small plate drilled and tapped or a nut welded to a plate besure to buy new screws at dealer tackweld a peace of wire to your new plate and fish in threw the top rear brake lite you will need someone to help start screws while you hold plate and lifgate.
Feb 24, 2010 | 2002 Jeep Liberty
Tried to bleed brakes by loosening the brake lines because the bleeder screws were broke off. it doesn't seem to be bleeding them good> what to do?
Only two options...remove the wheel cylinder asd carefully drill out the bleeder screw without damaging the threads or seat, or...replace the wheel cylinder (they aren't all that expensive). Since the line enters the cylinder lower that the bleeder, it is impossible to get the air out of there unless you turn the car upside down!!! No...don't try that!!!
Jul 06, 2009 | Ford Windstar Cars & Trucks
Broken key in ignition
you can only push this detent pin in when ignition is in on position try to put key that snapped in and wriggle it around to try and turn ignition to on position so then you can remove barrel
if cant turn need to change whole assembly by un doing shear pin for clamp that holds whole assembly on steering column or do what some lock smiths do drill out old barrel slowly and going up in drill sizes until barrel comes out from housing without damaging housing
Jun 29, 2009 | 1992 Chevrolet Corsica
Screw holding shelf bracket broke off, leaving much of the screw
the screw is probably a 1/4" srew. go to ace hardware or similar hardware store and tell them your problem and tell them you need a srew extractor. the one you can use in a cordless drill, it will drill and get the screw out in seconds.
Apr 07, 2009 | Refrigerators
Just replaced freezer fan a couple days ago. Now water leaking into top shelf of fridge. Could drain be clogged ? Frigidaire model FRT8S6ESBG.
Frozen drain
Ice maker water line and wiring
harness openings not sealed.
Seal water line and wiring harness
openings.
Drain trough not properly formed.
Ensure drain trough is at 90° angle to
back of freezer and that lip is up on front
and ends.
Divider (foam block) frozen.
Replace divider. Check drain trough.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 04, 2009 | Frigidaire FRT8S6ESB Stainless Steel Top...
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
23 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
