Question about GPS
Garmin nuvi 1370 will not connect to webupdater. when i try to connect to computer it will not find the device. when I select find device it get the folowing message: Some devices were found; however, none have the necessary capabilities. Pldease make sure your device is connected to the copmputer and turned on, then try again. You may also need to set the interface option on your GPS to 'Garmin' or 'Host'.
4 Suggested Answers
SOURCE: Webupdater won't detect Garmin unit
I have the same problem of the Nuvi 850 being recognized by webupdater. I downloaded 4.30 firmware update using this link http://www8.garmin.com/support/download_details.jsp?id=4043 plug the unit in and ran the update. It will ask you to disconnect once it is done. The unit will boot up after a few update progress bars. Plug it back in and launch webupdater.
Enjoy,
Fellow 850 owner.
Posted on Mar 26, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin 205 W has been discontinued and webupdater
I find that hard to be true. The manufactuer just came out with updates for the Nuvi 3xx and 6xx this month (Aug 09) and those models are older than your Nuvi 205W. When you mean updates are you referring to firmware or maps? Either way, even the discontinued models are still being supported with firmware & map updates.
If you are having trouble getting your unit updated, please let me know and I can help you with this.
- Jim
Posted on Aug 26, 2009
mc1bean
  • 3053 Answers
SOURCE: I need to set th interface option to garmin or
Hello Debbie,
Maybe this will help you some. I have found you the complete manual which covers most of the models of the Garmin Nuvi. It is the full manual from start to finish with complete operating procedures as well as schematics, operation instructions complete with pictures, and trouble shooting section and even other contact numbers to deal direct with Garmin, if your model is not covered in this manual.
Here is the link for you:
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Also if you can, please rate my solution if you can and some kind words would be appreciated. I also took the liberty to put my link at the bottom of this page that directs you to my personal page for all my areas of expertize, such as Automotive, Appliance, Electronics. Feel free to check it out anytime and save my link for future problem. Thanks So, Much Mike.
http://beta.fixya.com/users/mc1bean
Posted on Oct 25, 2011
Tip
Garmin Nuvi 1370 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1370 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1370 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1370 Manual Download
Garmin Nuvi 1370 QuickStart Download
Garmin Nuvi 1370 Webupdate
Garmin Nuvi 1370 Favorites Backup
on May 15, 2010 | GPS
My Garmin nuvi 1370 freezes when it is calculating.
Try doing a reset on the nuvi by pressing and holding the power button on for at least 10 seconds.
You could also try running the Garmin WebUpdater.
Download and Install WebUpdater.
Aug 17, 2011 | Garmin nuvi 1370T Car GPS Receiver
Computer can't locate connected nuvi 270
Are you using the latest Garmin program called WEBUPDATER Version 2.9.1.0 that was released about December 2009??
Try again:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Aug 22, 2009 | Garmin nuvi 350 GPS Receiver
Tip
Garmin Nuvi 1370 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1370 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
Garmin Nuvi 1370 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1370T Car GPS Receiver
Tip
Garmin Nuvi 1370 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
Tip
Garmin Nuvi 1250 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1250 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Tip
Garmin Nuvi 1245 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1245 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Tip
Garmin Nuvi 1200 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1200 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1200 Manual Download
Garmin Nuvi 1200 QuickStart Download
Garmin Nuvi 1200 Favorites Backup
Garmin Nuvi 1200 Hard Reset
on May 14, 2010 | GPS
Tip
Garmin Nuvi 1300 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1300 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
on May 13, 2010 | GPS
GPS Logo
153 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
