Question about Frigidaire FGHD2433KF Builtin Dishwasher
My Frigidaire fghd2433kf1 starting flashing PF occasionally. I would open and close the door and it would go away. It became more frequent until two days ago when the dishwasher stopped mid cycle and flashed PF. When I opened and closed the door, everything went dead and the dishwasher no longer works. It acts like it has no power coming into it. I checked the breakers and the wires connecting the power into the dishwasher. No luck. I replaced the control panel, but not the control board. It did not help. Hopefully you can help. Thanks.
3 Suggested Answers
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
  • 159 Answers
SOURCE: Flashes "CL" to close door when it is closed and won't start
The "CL" is telling you that "Child Lock" is on.
Nothing will happen until it is turned off.Information on this is in the booklet that came with your dishwasher.
Posted on May 29, 2010
When I close the door it flashes Pf when I push the button normal everything goes off. -It was worked on a couple months ago vent was bad but module board was also changed out. I unplugged it overnigh
PF is a power failure of some sort. Check your wiring to the dishwasher for loose connections. Opening and closing the door should have reset the error code, so you might also take a look at your door switch/latch to make sure it's working.
Good luck and let me know if I can be of further assistance to you.
Oct 24, 2014 | Frigidaire Dishwashers
Frigidaire dishwasher pf dims and stops
Hello Colton Rawlings, thank you for your post!
Based off what you are describing "PF" stands for power failure on a Frigidaire dishwasher. If the lights are dimming then your appliance flashes "PF" it could possibly be an issue within your panel or your appliance is not getting enough power to it. I would recommend contacting a professional to come and diagnose your appliance properly. I hope this is helpful. -Matt
Sep 06, 2014 | Frigidaire Dishwashers
Frigidaire Dishwasher Model:FDB1050RECO - When i push the start button all lights go out. I have to open and shut the door in order to start the unit this sometimes works...
same problem, wash light would flash, just like if the door was open during the wash cycle....took door apart and suspected the door switch was bad, fiddled with the wires that go to the door switch and the washer worked after that. so i had the door disassembled and used my hand to close the door latch switch then wiggled the white and black wires that go into the bottom of the switch, that is when it started to work.
wiggled with the wires for a while more while the washer was working to make it stop and start, until i found a good spot where it stayed working. been a few days and it is still working. need a new door switch if'/when it quits next time.
the door switch keeps the washer from running with the door open, it tells you the door is open by flashing the "wash" light when you try to start it. cheesy switch, my washer is only a few years old. i tried all the other things suggested, power on and off and hold down different combo's of buttons while standing on your head with your right eye closed, none of that worked so out came the screw driver.
figured if it was coming out to go to the dump i could not hurt it much more than it was at that time.
anyhow door switch was the problem, i hope this helps more people out there, i was close to throwing it out after not finding much for helpful advice online.
Dec 19, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
We have a frigidaire oven with flashing time and PF on display
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 10, 2010 | Frigidaire FEF336BC Electric Kitchen Range
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 | Ovens
Frigidaire FGHD2433KF Builtin Dishwasher Logo
446 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
