Hi, you can try the following process: RESTORE COMPUTER TO ITS ORIGINAL SETTINGS WITHOUT RECOVERY CDs
This process will restore the c:drive with the original software that is installed when youpurchase your netbook. follow the steps to rebuild the c:drive which will be reformatted.
Check the BIOS settings
-Make sure the acer d2d (disk to disk) recover setting in MAIN is ENABLED
-Exit the BIOS and save changes. the system will reboot.
- Activate the BIOS by pressing the F2 key as your computer starts up.
TO START THE RECOVERY PROCESS (here's where it didn't do anything)
-Start the system
-While the acer logo is showing, press alt and f10 at the same time to enter the recovery process.
-Refer to the onscreen instructions to perform system recovery
When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
If you are prompted with a Microsoft Windows boot screen, press the Enter key.
After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.
Instructions Things You'll Need: Acer PC or laptop Step 1: Click "Start" menu. Step 2: Click "Programs." Step 3: Click "Acer Recovery Management." Step 4: Click the "Restore" button on the bottom of the dialog box that opens. Step 5: Click "Restore System to Factory Default." Step 6: Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process. Step 7: Click "Start" to restore the computer to the default factory settings. Tips & Warnings If you are unable to access the Start menu, use the recovery CDs that came with the computer or visit Acer's website (see Resources below). Always make a back-up CD before restoring a computer to factory defaults. Resources Acer Website
It appears that the Windows is corrupted on your computer, you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Launching Acer eRecovery Management 1 You may also launch Acer eRecovery Management by running the program from the Acer program group in the Start menu, or by double-clicking the icon if you have created a desktop shortcut. 2 You can choose to restore the system from a factory default image or reinstall applications and drivers. 3 Follow the instructions on screen to complete the process. Note: External optical disc drive required. Please see your retailer for more details.
Enable disk-to-disk recovery To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility, then select Main from the categories listed at the top of the screen. Find D2D Recovery at the bottom of the screen and use the and keys to set this value to Enabled.
Is the system running MS Vista? I had this problem with a PC the other day. What I ended up doing was using an XP disk to format the HDD, then before I rebooted I ejected the XP disk and insterted the recovery disk. When the system rebooted, THEN it booted from the recovery disk.
if the recovery disk came with the system yes it will have a copy of everything that came on the PC when you bought it if you upgraded th OS you will have to do a upgrade after you have used the recovery disk.
by using the recovery disk you will return every thing back to the factory so you will lose all your saved data, bookmarks, pic, and doc's.
