Question about GE Spacemaker JVM1640SJ Microwave Oven
Door handle has broken loose at bottom of handle and needs to be replaced. How can this be accomplished?
  • 5,911 Answers
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Nov 10, 2010
The bottom of the door handle has broken loose. There doesn't appear to be screws on the inside of the door. Can I order a new handle and replace it (how do I take the door apart) - or am i going to need...
Go to RepairClinic.com. They have detailed exploded views of many appliances. This will show you how to replace the door handle or what you need to do..
Jan 16, 2011 | Microwave Ovens
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing a whirlpool microwave door handle! got the new handle..how do I open the door up to screw the new handle on?
To replace the door handle you need to access the door handle screws. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 24, 2009 | Whirlpool MH7140XF Microwave Oven
The bottom handle attachment on our MH7140XF microwave is broken. Ordered another handle but I can't figure how to remove the old one. Help!
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find links to helpful exploded view diagrams and part ordering help here.
Nov 22, 2009 | Whirlpool MH7140XF Microwave Oven
Need to replace the handle
You will need to access the door handle mounting screws and remove them to replace the door handle. To access these screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
Nov 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle on my GE Spacemaker XL model JVM1330BW 003 broke off so I decided to replace the entire oven. Can you recommend a replacement that will fit into the same recess and have the exhaust vent...
If the outer door is not broken. All you have to do is replace the handle. You will need to access the door handle mounting screws and remove them to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. The part number for the door handle is WB15X10020. If the outer panel is damaged, you may have to replace the entire door. The part number is WB55X991. The cheapest web source I have found the handle listed is appliancepartspros.com for $47. The entire door, however, sells for $110 at pcappliancerepair.com.
The RF inside the cavity of a microwave oven is actually controlled by the RF shield in the glass. As long as the glass is intact and the inner door facing is not bowed, warped or cracked, you will not have to worry about RF leakage (even with the handle broken off).
Nov 03, 2009 | Microwave Ovens
How to replace door handle on microwave frigidare fmv156dcc
You will need to access the door handle mounting screws and remove it to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife to carefully pry the plastic up and work your way slowly around the perimiter of the glass to pop the panel loose. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place and seats properly.
Oct 15, 2009 | Frigidaire FMV156DC Microwave Oven
Replace door handle on microwave Kitchenaid KHHS179LSS. I have the part.
You will need to access the door handle mounting screws and remove it to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife to carefully insert in the seam and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches. NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
Oct 15, 2009 | Microwave Ovens
Microwave broken door handle.
To replace MOST microwave oven door handles all you have to do is open the door and remove the inner plastic panel around the glass. This is accomplished by taking a small screwdriver and carefully inserting it along the perimeter to pop it loose (there are usually some grooves you can insert the screwdriver in).
NOTE: DO NOT pry against the glass. The glass is tempered and has an RF shield that protects the consumer from the microwaves being generated by the magnetron. Breaking it, requires a new door replacement.
With the panel removed, you will be able to access the screws that hold the handle in place. Once the new handle is in place, carefully reinsert the inner plastic panel by snapping it back in place all the way around the perimeter of the door glass.
If you have questions, or if your door is configured differently, please let me know. If you have the ability to send photos, that helps too. A model number may also be useful so I can identify how your door is assembled. I hope this helps you,
Apr 23, 2009 | Microwave Ovens
Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,019 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
