Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Lawnmower problem my lawnmower is hard to start and will not stay started after it does start? I Have replaced the spark plug and re placed with new gas and oil..any help you can give please?
  • lmcclellan18 Aug 25, 2008
    MY LAWNMOWER WILL START UP BUT WILL NOT STAY STARTED. I HAVE CHANGED THE SPARK PLUG AND PUT IN NEW GAS AND OIL. CAN YOU PLEASE HELP ME FIX THIS PROBLEM? i HAVE A TROY BILT MOWER (PUSH MOWER)
    New Friend:
My lawmower can"t start
Posted on Jun 06, 2013
    Champion:
  • 313 Answers
For trouble shooting & repair check out www.smallengineadvisor.com for problem solving etc.
Posted on Jun 17, 2008
My cub cadet 1046 riding lawnmower won't stay running. I've replaced the fuel filter, both spark plugs, and sprayed carburetor ports with carburetor cleaner and it starts but won't stay running.
When you say "stay running", how long does it actually run for? Will it ALWAYS start and run, even if it dies, or will it sometimes not run at all and only turn over?
Mar 21, 2017 | Cub Cadet Garden
No fire to plug was running new engine
How to fix a lawnmower no spark - YouTube
? 11:58
www.youtube.com/watch?v=ckyFlX4CUVU
May 1, 2012 - Uploaded by doublewide6 I got new spark plug still cant start my lawnmower any sujetions... Engine is hard to pull start and get to fire when it's cold but after it does start ...
Sep 19, 2015 | Garden
My Husqvarna model 38096 will not stay running. Cleaned carb, new plug, new gas.
Hi Sonny:
This is the chainsaw section but I think you're playing with a lawnmower, right?
You're saying that it won't stay running. That tells me that it does start, so the spark is OK, and I'd be looking for a fuel delivery problem. Since you cleaned the carb, I'd be looking at a plugged fuel filter or possibly bad fuel.
Jul 09, 2015 | Husqvarna Garden
Mowing at mid throttle, suddenly the engine started over revving. Acts like governor isn't working. Every time I try to restart it instantly starts to over rev.
According to Amie Taylor on http://homeguides.sfgate.com/lawnmower-revs-up-down-100220.html "Airflow Issues A lawnmower that hunts and surges may be experiencing something as simple as an airflow issue. If the air that the engine requires to run is blocked, especially sporadically, it can cause the engine to slow down. When the blockage moves or clears, the engine may suddenly rev up in response. To fix this type of problem, check the air filter to ensure that it's not clogged with dirt and debris. Check the vented gas cap as well. Both issues can cause reduced or sporadic air flow, and clearing them will fix the problem.
Spark Plug Problems Another problem that can cause revving and dying of a lawnmower engine is a faulty or poorly adjusted spark plug. Check the spark plug to see if the wire is connected to it firmly and not wobbling about. If it is connected correctly, remove the spark plug to see if it's covered with corrosion. If so, a simple scrubbing with a wire brush can restore it to working order. If necessary, replace the spark plug with a new one. Check the spark plug gap with a spark plug gauge to ensure that it's adjusted to the proper setting recommended in your owner's manual.
Carburetor Adjustment A carburetor that's incorrectly adjusted is a common cause of poor engine idling that results in hunting and surging. Fortunately, most lawnmowers have two screws that allow you to adjust the carburetor yourself. One screw controls the idle speed while the other adjusts the idle mixture. Check the manual if you're unsure of the location of the idle adjustment screws. Start the mower and allow it to run for 5 minutes. Then slowly adjust the screws tighter or looser in turn until the mower runs and idles smoothly.
Fuel Problems A particularly simple fix that can be at the bottom of many lawnmower idling problems is old or contaminated fuel. If the fuel has been left in the mower while it was stored over the winter or while the mower has remained unused, drain it and replace it with fresh fuel. If you have gas-powered blowers and trimmers that use a mixture of 2-cycle oil and gasoline, check to see that you've not placed that mixture in the lawnmower inadvertently."
May 10, 2015 | Garden
Craftsman gold 6.0 hp. walk behind lawnmower wont start
Back to basics, is the fuel in the tank good?( fill with fresh fuel ) does it have a spark at the plug?(remove the plug, earth against the cylinder, is there a spark,if not, replace the spark plug and try again ) does the plug wet with fue lafter pulling?( clean/service carb ) is the spark occuring in the correct place ( flywheel key sheard ) has the engine got good compression?
Aug 19, 2013 | Briggs & Stratton Briggs Stratton...
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
Spark plug wet will not start on lawnmower 6.75
you're still fighting with the large amount of fuel that was in it the first time it was flooded. One way to get the rest of it out, is to take the spark plug out, and pull the starting rope hard several times to force some of the fuel out. leave the plug out for a while, and pull it again every 10 minutes or so to introduce new air and get the fuel out. If you're not that patient, you can flash the cylinder, but be cautious with it. This is where you use a lighter to flash the cylinder. You can only do this if there's no fuel spilled on the mower, and never put your face near the spark plug hole; it will give a loud puff sound and you may have flames jet out, but only for a fraction of a second. Then put the spark plug in, and it will probably start first pull.
Mar 18, 2010 | Garden
I have a lawnmower with a BSA 3.5 engine that I cannot start, the problem seems to be no spark at the spark plug. As I have never worked on a lawnmower I have no idea what generates the spark on...
Test for spark by placing a screwdriver into the spark plug wire and holding it close to a bolt on the engine. should see a spark (blue). If not, problem is likely the armature (coil). The coil is located under the engine shroud and held in place by two bolts. If you replace this part, (normally $30 to $40) you must ensure a proper air gap. Auto parts stores have inexpensive repair manuals to help.
Lee
Cherokee Small Engines
Apr 21, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
474 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
