Question about Intermatic Inc. ST01C Digital In-Wall Timer
I am trying to program the light switch do not have the instructions
If I understand correctly, you have the ST01C timer.
The following webpage has the manual and step by step instructions:
http://waterheatertimer.org/ST01C-program.html
The page also shows other programmable timers in case you have a different model number.
Posted on Nov 10, 2010
I have the EJ351 mechanical in-wall timer for my outdoor garage lights which are LED.I set the timer but lights go on way early Is there another method for programming the switch that I could try.
This is not a mechanical timer; it has a solid-state switch. It is designed for incandescent lights, and is not recommended for CFL or LED lamps. It may work properly with dimmable LED lights if you have at least four (total 32 Watts or more) connected.
You can try programming using the 24-hour method described at the top of page 2 of the manual. I've provided the link to the manual below.
https://www.intermatic.com/-/media/inriver/6842-8228.ashx/EJ351-Instructions-EN
Jul 08, 2017 | Hardware & Accessories
I lost the 27208 remote that came with two contractor-installed Hunter fans with lights (incandescent). The fans, lights, & remote have worked fine for 5 years. I purchased a new 27209 remote at Lowes...
If you are trying to use a combination of wall switch and pull chain control, the simple logic in the receiver can't figure out what to do. Try disconnecting all fan power at the source, removing and reinstalling the remote battery, restoring power, and trying all combinations of switch settings and power off - power on operation until you get results (or give up).
Feb 28, 2017 | Hunter Dryers
Westek SLC6CFL programming instructions
Copy following link for Westek outdoor socket timer instructions:
http://waterheatertimer.org/pdf/Westek-SLC6CFL-timer-instructions.pdf
Jun 27, 2012 | Ace Hardware AMERICAN TACK 3236858...
I have a intermatic ej351c indoor wall switch programmable timer that I have tried several time to program an on time for the lights to come on however the lights does come on. I have followed the...
There might be a couple things that are easy to overlook.
Press the button to see if lights come on >>> if light do not turn on with manual override, then light might be burned out or circuit breaker tripped. Sometimes a breaker is tripped but you can't tell by looking at it
1) The timer is used on incandescent bulbs only. I don't know why, but it says no
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
2) Is the red indicator light ON?
For programs to work, timer has to be in automatic mode and the red indicator light will be ON
The Switch Timer can be used in two modes. manual & automatic
To switch between modes, quickly press the dial twice:
AUTOMATIC MODE: The Switch Timer will turn your lights ON or OFF according to programmed settings. The RED indicator light stays ON when in Automatic Mode.
MANUAL MODE: Programmed settings are inactive, and
the Switch Timer will only turn the light ON or OFF when
you push on the dial.
RED indicator light stays OFF when in Manual mode.
3) setting current time> lets look at the red indicator light while doing this
Move switch lever to OFF-Clear
Move lever to ON >>> red indicator is flashing
Rotate dial to nearest current time (if it's 7:20 pm, rotate dial to 7:30pm)
Press the dial once to set current time > red indicator light goes off
Do not accidentally press dial or it will set the wrong time....ok we know that
4) overlapping programs/
Make a chart of the times you want to program with ON and OFF plus am & pm
Check your chart for overlapping times that tell the timer to do more than one thing
Rotate dial clockwise to the first ON time >> pay attention to am & pm
Press button and first ON time is set
Rotate dial clockwise to the first OFF time >> watch the am and pm
Press button and first OFF time is set
You can have 48 on-off times >>> which seems a lot for a 24 hour repeat timer
5) try the timer with one program
6) If timer still doesn't work, put switch back in and see if lights turn on that way >>> it could be a loose wire suddenly cropped up
Last step >>> timer is no good, you need another one. We tried.
Oct 16, 2010 | Electrical Supplies
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
How do i program the LEVITON Decora Timer Light Switch 10/24hrs.
From this website you can download a free instruction sheet in PDF format...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=6216&section=17138
May 12, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Instructions on how to program the Intermatic EJ351C
take a look at this :
-or -
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
hope this helps
Jun 03, 2009 | Intermatic Programmable 24 Wall Switch...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
98 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
