Question about Brother MFC-640CW All-In-One InkJet Printer
Hello, I have a Brother MFC-640CW that show a paper jam error message, but no paper jam in the printer. I have inspected the printer and can't find anything, how can I clear the error message, or repair it.
  • 1,218 Answers
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Posted on Nov 10, 2010
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
MFC640 Printer had a paper jam I took the paper out from the back put the cover back on its still flashing paper jam. what should I do?
TRY OPENING AND INSPECTING ALL AREAS WHERE THE PAPER GOES. USE A TORCH OR BRIGHT LIGHT TO CHECK IF THERE ANY BITS OF PAPER. ALSO CHECK IF ANY BITS MISSING FROM THE JAMBED SHEET OF PAPER. LOOK FOR A SMALL PIECE OF PAPER. AROUND THE ROLLERS OR PAPER MOVEMENT AREA. .ALSO IF PRINT HEAD IS ON LEFT SIDE GENTLY MOVE IT TO THE CENTRE WITHOUT TOUCHING ANYTHING, AND CHECK FOR ANY PAPER BITS BEHIND THE PRINT HEAD..
TO DO THIS YOU MUST REMOVE THE PAPER JAM COVER AT REAR OF MACHINE, LIFT UP THE WHOLE SCANNER COVER AND INSPECT. WHEN COMPLETE REPLACE THE REAR COVER AND CLOSE THE MACHINE. THEN RETRY.
HOPE THIS HELPS BARRY UBON.
May 08, 2011 | Brother MFC-640CW All-In-One InkJet...
MFC-640CW Switch on error message: "Unable to Init! - User Guide says this is a mechanical fault or jam - not a jam all clear. There is an empty Cyan ink cartridge message as well which is correct. Also...
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Nov 09, 2009 | Brother MFC-640CW All-In-One InkJet...
Paper jam-no jam
try doing a reset if that doesnt work is it under a warenty? if so then i would return it printers are tricky things to fix so many small parts
Jan 07, 2009 | Brother MFC-640CW All-In-One InkJet...
Paper Jam
sometimes the paper gets jam internally if the small piece of paper is just not letting the gears to move fluently this problem cad occur.for resolving this the whole printer needs to be opened and cleaned part by part.
but sometimes unplugging the printer from the main power outlet for sometime the replugging it again resolves the problem.
Dec 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Mfc-640cw
Yes. There is some paper left in the very edge (mostly left hand side). Have a good look there by opening the scanner top.
Feb 27, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-640CW All-In-One InkJet Printer Logo
383 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
