Question about Ariens Garden
I have a Arien's ST724 7hp snow blower and I like to install a electric start , but I do not the model to buy the starter for my snow blower , please can you help me and how to install too .thank you . Jorge Reinoso
  • 293 Answers
Jorge, You most likley have a Techuseh 7 0r 8 hp engine. The big problem is that it does not have a stator under the flywheel to allow you to charge the battery or run lights. So the cheapest way for you to add electric start is to buy a 120 volt strter that will just bolt on. You will have to use an extension cord to use it though. You can get the starter from any small engine shop. You just need the engine numbers when you are asking for prices and availablity. The instructions are easy to follow.
Hope this helps
Posted on Nov 10, 2010
I have an arien 8524 snow blower. Is there an air filter on this snow blower as my snow blower will not stay running it only starts and runs for about 20 seconds
Most snow blowers do not have air filters. They tend to clog on these units. Sounds like your issues are fuel related. You may try to flush the system with a product called "Start" from Wal-Mart. You will need to follow the instructions on the bottle and try to keep the unit running long enough to run this cleaner through the system.
Feb 13, 2017 | Garden
I have a 26inch Craftsman's snow blower that won't turn over, I tried the rope and electric starter and it won't turn.
If motor is not turning it is possible that it is seized.up.
BTW there is a significant difference between not turning over and not starting.
Jan 11, 2017 | Electric Garden
I have an ARIEN snowblower Model 921031 24". It will not start. Please help me remedy this. Thank You ....Eddie
If there is adjusting screw on the carb open it up a part of a turn and see what happens I had to do that to my Craftsman Blower. Open is left If that does not work
Take the spark plug out and shoot a little bit of gas into the plug hole then put the plug back in. Try to start it. If it starts and stalls then try two or three times. Make sure you have fresh gas as well.
Dec 20, 2016 | Garden
Won't start. Even using electric start function.
try a spritz of Starter Fluid, if it tries to start then you know you need to clean the carburetor that was probably ruined by ETHANOL gas
Nov 21, 2015 | Poulan Pro 24" 2Stage Snow Blower Electric...
How to fix electric start on poulan pr270
Sounds like your drive gears on the starter are shot.
I took my starter off and took it to a small engines shop and he repaired it for $25.00. He said i could have fixed it myself but the little springs are hard to line up and you have to know what you are doing.
Mar 08, 2015 | Poulan Pro 27" 2Stage Snow Blower Electric...
Sears model 1150 snow thrower how repairing the electric connecter for sears model 1150 snow thrower
It's just a simple AC pronged piece. You can buy the actual piece from Sears OR you can buy an Electric Line-cord and wire it into teh plastic box where the Push button 'Start ' switch is.
Mar 01, 2015 | Garden
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Troy built snow blower the electric starter grinds
sounds like your starter pinion is stripped. remove your starter and inspect the gear. If the teeth are worn then replace gear if not replace starter. you will also want to check the teeth on your flywheel
Oct 07, 2014 | Garden
Troybuilt snowblow electric starter won't start or turn over. Nothing happens. What could be wrong
if it does nothing, check to be sure you have 120v power out of cord
push starter button do you hear a click/ if not micro swtch is bad
if you do than starter motor is bad
Jan 28, 2014 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Electric start just wines & dont start the snow blower
Pull off your starter and look at your gear on starter, sounds like it isn't engaging, may need to replace that gear on the end of starter
Nov 27, 2011 | Garden
Garden Logo
472 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
