Question about Merlin Televison & Video
Merlin Remote Control Openers , Model 430R Installed 7 Years ago, Working fine until Today! The Problem is, when closing the B&D Roller Door using the remote, the Door closes but after a few second it opens again and it stays open. Tried it several times, but still the same. When switching the Mains Power off then on, the light falshes 3 times, like it is resetting, but the Fault still persists. I am hoping that You can Help me, Regards Werner
    Habit-Forming:
  • 138 Answers
Do you have an error code
Posted on Jun 16, 2017
SOURCE: BMW remote control problem
I have a e60 525i that I just brought and it has the same problem, the owners manual suggests driving with the key in the ignition for a long time as the batteries are rechargable and may have gone flat, i have tried this and it doesnt seem to work
i also read something about getting water in the aerial about the rear window and that wrecks the receiever. My car isn;t under warranty so not looking forwarding to taking it to bmw
Posted on Jun 27, 2008
ktkodama
  • 37 Answers
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Posted on Jan 20, 2009
  • 11 Answers
SOURCE: Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Posted on Jan 25, 2009
SOURCE: Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Posted on Jan 27, 2009
  • 3197 Answers
SOURCE: Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Posted on Aug 26, 2009
I have older model Merlin 430R door openers but can't find "learn button" to connect new remotes There is no green cover to remove
If the opener is the Merlin ProLift 430R, then there should be a Red learn button under the green control panel cover on the left side of the front of the garage door opener. (There is a black cover on the right side of the front of the opener.) See https://www.manualslib.com/manual/886850/Merlin-Prolift-430r.html?page=4#manual for a picture of the control panel. The learn button is in the center of the set of three buttons between the open and close force dials.
To use the learn button, you need to press and hold the button for 1-2 seconds until the courtesy lamp flashes. If you hold the button for 11 seconds or more, the garage door opener will forget all of the remotes. See https://www.manualslib.com/manual/886850/Merlin-Prolift-430r.html?page=6#manual .
I hope this helps.
Aug 26, 2018 | Building Materials
After adjusting the tension on the roller door, with a Merlin 430r the door the door Will not close completely.
There could be several reasons as to why this is happening. Not sure if this would help but here is a manual on the opener: https://www.manualslib.com/manual/886850/Merlin-Prolift-430r.html#manual
May 27, 2018 | Building Materials
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
The range for the remote openers (4) for mu Liftmaster garage door opener has decreased to the point of having to be within 6 feet of the door to open it. The liftmaster was installed 5 yrs ago. The...
There is an antenna extender kit available for your opener. The part number is 41A3504 and should be available from any good door opener company that handles Liftmaster or Chamberlain. It should come with instructions.
Jul 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
My mom & I each have a Craftsman garage door opener at our respective homes & live @ 15 minutes apart. Our openers are about 13 to 14 yrs old. The past two yrs. we've both had the same problem. ...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure both lights on the sensors stay on and don't flicker while the door is moving and the sensors are firmly attached so they don't move. Tweak them just a bit.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close by remote in cold weather
There are ususally two adjustments on garage door openers...
One is for the pressure and the other is for the travel. Assuming that the travel adjustment is properly adjusted...
On a cold day things are a little tighter and it "wants" a little more downwards pressure to complete its cycle. Sorta like me in the morning -- I need a little coffee to get going on a cold morning.
Adjust the down pressure/force just enough to make the unit close properly. Do not over adjust the down pressure or you will find it won't stay closed. Sometimes the manufacturer doesn't make it too clear where this adjustment is, but you should be able to find it if you look around.
I have seen units that were installed for years all of a sudden need a little tweak of this adjustment.
Good luck
Mar 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
180 people viewed this question
Top Merlin Televison & Video Experts
Marvin
Marvin
Are you a Merlin Televison and Video Expert? Answer questions, earn points and help others
