Question about Gateway MX6920 Notebook
Does my protection plan cover a damaged LCD screen on my laptop?
My laptop screen has been damaged due to closing the laptop. There are black marks covering a section of the screen. Is this damage covered by my Service Protection Plan?
  • countrygirl3 Jun 17, 2008
    Please give me any information or what to do.
  • 63 Answers
It depends on the warranty you purchased. Most basic warranties do not cover accidental damage, such as the damage your laptop sustained. Your best bet is to contact Gateway directly - they will be able to determine your warranty coverage. (Or if you purchased through a store like Best Buy, take it to them.) If you do not have ADP, you would have to pay for the repairs out of pocket.
Posted on Jun 17, 2008
Pink screen
Problem can be;
1) Graphics chipset
2) Video Cable
3) screen Inverter (IF Used)
4) LCD screen
Diagnose to find out.
I need the laptop manufacturer name, and model number.
Model number can be found on the Bottom of the laptop.
Post back in a Comment.
A) Graphics chipset:
An external monitor is used to check, and see if the display is also pinkish on it; or it is OK. Info posted I need, I will detail this procedure out step by step.
Display good on external monitor means graphics chipset is OK.
(Mounting is usually the problem)
Means problem is screen Inverter (IF used), or Video Cable, or LCD screen.
B) Video Cable:
The Video Cable connects to the motherboard, in an area under the Keyboard, or under the Switch Cover.
(Depending on laptop design, Switch Cover may be an integral part of Palm Rest Cover)
From there it leads under, or close by the left Hinge; and then goes up into the Display Assembly.
IF, a screen Inverter is used, the Video Cable has a separate small cable that branches off; and connects to one side of the screen Inverter.
The main part of the Video Cable connects to the back of the LCD screen.
Just due to normal repeated opening, and closing of the laptop; the Video Cable may become pulled on, and/or pinched.
This can lead to a loose connection at the motherboard side, or LCD screen side. (and/or screen Inverter, IF screen Inverter is used)
Can also lead to a damaged Video Cable. (Stretched/Broken wires inside it)
This can cause a pinkish screen.
C) screen Inverter:
With Backlighting that uses CCFL/s for a Backlight, a screen Inverter is used.
(Cold Cathode Fluorescent Lamp)
For Backlighting that is LED, a screen Inverter MAY, or MAY NOT be used.
(First design LED backlighting seemed to. Later design LED backlighting, does not. Light Emitting Diode)
A screen Inverter is used to convert the power (Electricity), from the laptop; for the LCD screen and Backlight.
Screen Inverter going out, can cause a pinkish screen.
D) LCD screen:
Graphics chipset is good, Video Cable connections are good; no damaged Video Cable, screen Inverter is good (IF used); problem is LCD screen.
Awaiting manufacturer name, and model number.
Regards,
joecoolvette
Apr 30, 2013 | Computers & Internet
Advent 4211 screen to base connection problem
Video Cable
The Video Cable connects to the motherboard.
It then runs along under the Left Hinge, and connects to the back of LCD screen.
{LED backlighting. Does not use a screen Inverter]
Due to just normal opening, and closing of the laptop; the Video Cable may be pinched.
This can cause the connection of the Video Cable TO motherboard, to be loose; and/or LCD screen.
Solution is to partially disassemble the laptop, and PHYSICALLY make sure the connection at motherboard is tight.
Visual inspection will NOT do.
Connection at back of LCD screen needs to be Physically checked also. (Try to plug in tighter)
Also visually inspect the sheath of the Video Cable, for apparent signs of damage.
Any signs of damage to the sheath, may mean damage to the tiny wires inside the Video Cable.
(Stretched/Broken)
Also due to the age of the laptop, suspect cracking of the insulation, of the wires inside the Video Cable.
If you have a multimeter, set it to OHM's (1K), and check continuity of every wire in the Video Cable.
Or take it to a small computer store, and have the resident tech check it.
The Advent 4211 is just a rebadged MSI Wind U100, according to my findings,
Disassembly guide,
http://www.bit-tech.net/hardware/laptops/2008/07/05/breaking-wind/1
That's the problem, the Video Cable,
http://microdream.co.uk/advent-4211-c-lcd-screen-cable-k19-3030019-h58.html
[ In the photo, the large connector at bottom plugs into the LCD screen.
The smaller connector at the upper right plugs into the motherboard.
The separate black wire you see with the eyelet on it, is a Ground wire ]
For additional questions please post in a Comment
Regards,
joecoolvette
Dec 14, 2012 | Advent 4211c Notebook
Black marks on screen i think it needs a degaus but dont know how to do it
LCD monitors do not need degaussing. They operate in a completely way to CRT monitors.
Tiny black marks are most likely dead pixels, if the black marks are large then the LCD screen may be damaged (cracked glass).
This type of damage cannot be repaired simply, the screen needs to be replaced.
I suggest you put your money towards a new LCD monitor.
Sep 03, 2010 | LG Flatron L1710M 17" LCD Monitor
Screen craking guaranty my laptop screen damage i take 1 year ago and also under guaranty preoid
Contact Compaq here:
http://h18000.www1.hp.com/cpq-country/cpq_support.html?jumpid=hpr_R1002_USEN
Dec 11, 2009 | Compaq Presario CQ60-220US PC Laptop
What do I need to do with my laptop? My son
the LCD probably is probably damaged. visit any Notebook shop and have it replaced... just the LCD...
Aug 10, 2009 | HP Compaq 6720s Notebook
Laptop has a black screen
hello,
your LCD screen maybe damage due to impact i suggest you bring it to the computer shop for repair. most common damage are the screen and hard drive due to strong impact.
regards
Jul 13, 2009 | Computers & Internet
Hi i want to know the adress to send my hp laptop for a reparation in canada because my screen is broke
First of all....make sure that your notebook is covered with Accidental Damage Protection Plan.
If your Notebook is under normal Factory Warranty provided by HP, you cannot get the LCD replaced for free.
However, you need to contact HP Technical support either through Telephone if the Notebook is under warranty or Chat Support even if the Notebook is out of warranty to get the required details.
Additionally, if the Notebook is out of warranty, I recommend you to go for a new Notebook rather than getting the LCD Replaced since replacing the LCD will cost you as of a new Basic Notebook.
However, if you wish to get the Notebook repaired by HP, you can contact any nearest BestBuy, CompUSA or RadioShack stores which are HP Authorized Service Providers.
Hope this helps.
Sep 02, 2008 | HP Pavilion dv6000z Notebook
BROKEN LAPTOP
this one has to go back through HP..sorry to report that.
Jun 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Laptop upper part screen burn
If you are talking about the plastic cover, you can do that. If you have never been under the covers on this unit, it will probably take 2-3 hours to do it. I'd suggest looking somewhere like Ebay to try to pick up a used, non functioning LCD unit, for as cheap as you can. Went you take the parts out of the used unit, you should have a pretty good idea as how to replace the cover on your unit.
Ron-
Feb 22, 2008 | HP Compaq Presario V2000 Notebook
Black Spots on LCD for Latitude D505
If you?re positive that the black spots aren?t dirt or scratches on the outside of your screen you are probably dealing with dead screen pixels. Short of replacing the LCD screen there is no way to repair them.
Dec 13, 2006 | Dell Latitude D505 Notebook
Gateway MX6920 Notebook Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
