Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
The oven showed an F1 and spark came from the clock panel, turned the power off and no F1 code.The oven will not heat?
  • 33 Answers
It sounds like you may have a short in your panel...
Posted on Nov 10, 2010
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Oven is giving an F1 error code
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 29, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F1 is showing on my oven
(Clock).
Dec 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven is showing a f1 error
F1
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
1. Disconnect
has been disconnected, so please double check before continuing.
2. Gain
keypad or membrane switch) ribbon from the ERC.
on. Assemble the control panel back the way it was.
on.
accompanied by a beeping sound).
Dec 14, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 | Ovens
LCD displays trouble code F1. The serial # is MEW6627BAW this is a double wall oven.
HI, this code represents a Defective touch pad or clock (ERC)
May 18, 2009 | Maytag MEW6627B Electric Double Oven
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F1 keeps flashing...
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
*&^ty
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
49 people viewed this question
Top Frigidaire Ovens Experts
Craig Butler
Craig Butler
Sal De
Marvin
Marvin
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
