Question about Maytag Bravos MTW6600T Top Load Washer
My washer is one month old. The clean washer reminder came on so I followed the directions and put in an affresh tablet. The washer has a "LF" code about 10 minutes into the cycle. I know that means it's taking too long to fill....suggestions?
  • 33 Answers
You may need to unhook the water lines and make sure the lines arent being clogged up
Posted on Nov 10, 2010
What should I do when the 'clean washer reminder' light goes on?
Hello, Thank You for using FixYa. I will be helping you today.You should run the clean washer cycle with a cup of bleach or an Affresh tablet.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 05, 2011 | Maytag Washing Machines
How do i clean the washer?
you need to put affresh tablets into the tub and set it to clean cycle if it has it or heavy duty with hot water. you can get affresh tablets at just about any store in the laundry detergent isle.
Jun 06, 2011 | Frigidaire ATF6000ES Front Load Washer
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Jan 14, 2010 | Maytag Bravos MTW6600T Top Load Washer
What does the clean washer reminder light mean and what do I do to clean the machine? This washer was new in September, 09 and the light has been on for several weeks.
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset the indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Nov 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
Where do i have to clean it at?
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. And if you were getting the Sd code it should also be gone. You can also reset this by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Oct 11, 2009 | Maytag Bravos MTW6600T Top Load Washer
Clean washer reminder---what do i do when this indicator lights?
Aug 08, 2009 | Maytag Washing Machines
Clothes smell of old dirty water, after washing
this will solve your problems
Affresh™ Washer Cleaning Kit Affresh™ Washer Cleaning Kit contains 3 Power Puck tablets and 6 Grit Grabber cloths. The tablets remove and prevents odor-causing residue that can occur in all brands of HE washers. Affresh™ cleaner is a formulated, slow-dissolve, foaming tablet that gets under residue, breaks it up, and washes it away leaving the washer smelling fresh and clean. Simply place one tablet in the wash basket (without clothes) and run a Normal Cycle (hot option) or Clean Washer Cycle. The Grit Grabber™ premoistened cloths have been formulated to penetrate, dissolve and remove odor-causing residue from the rubber door seal. Now consumers can clean where they can't reach with the Power Puck™ tablets and where they can with the Grit Grabber™ cloth. Affresh™ brand is environmentally friendly, safe on septic tanks, and safe for all washer components. Package includes three tablets. Part #W10194073 $10.99
Please remember to leave a solved rating!
Dec 07, 2008 | Whirlpool Washing Machines
My water has been smelling of sulfur. The clothes I was end up smelling of BO after being worn for only a short time. It isnt that the person is smell it is the clothing. Is there something to be added to...
I found that WasherFresh worked better then the Affresh.  What I really did not like is you cannot touch the Affresh tablets, WasherFresh is contained in a pouch and is not harmful to touch, because of the disolving pouch containing the chemicals.  Also after reading the package the chemicals are not harmful to the environment.
WasherFresh removed the odor causing buildup and I now use it monthly as a preventive maintenance.
Sep 30, 2008 | Estate TAWX700JQ Top Load Washer
Whirlpool duet washer ghw9100lw1
That is not what it is. I would recommend either going to the website affresh.com or best buy/home depot carry this product
Its called Affresh, comes in a green package 3 tablets in each package. Retails at 6.99$ (not sure about in store prices)
Front loads can not drain all water and residue because of gravity. This builds up and causes molding/odor issues in some units
Affresh was solely created to resolve this and replace the Bleach Clean Procedure.
Easy to use, put tablet directly in tub, no clothes or detergent, hot water, normal cycle selection and run it. In your case the idea is to run 3 consecutive washes (1 table per wash) then once monthly after that(1 wash same directions but only the first time you do 3 washes). This will resolve the issues, i use it and buy it for my family and friends.
May 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
361 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
