Question about Fuji FinePix S5000 Digital Camera
No Power Recharged batteries night before. Test Camera for batterie power, everything was working. Next day I went to use camera, and it is totally dead! I even went and bought brand new DBL A batteries to see if camera would boot, and it don't. I tested both boughten batteries and rechargable batteries with a tester, both type of batteries have plenty of power.
  • 3 more comments
  • fabricanonym Jun 22, 2008
    Yes, memory card in camera. I even switched memory cards to make sure it wasn't the memory card. Additionally memory card only loads one way, so I don't have memory card in wrong.
  • Anonymous Jun 29, 2008
    wont turn on replaced batteries still wont work
  • Anonymous Feb 16, 2009
    yes will not turn on HELP
  • tcbandme Feb 26, 2009
    Have tried several types of batteries all in excellent power load. Tested the memory card via pc. Camera still either wont start or starts and shuts down in 30 seconds.
    Bad camera sell it and get another!
  • lindalahue Feb 26, 2009
    hi, my camera was working fine last night, then next thing it went dead, changed barreries and memory card, still nothing please help
Did you make sure you have a memory card in the camera, i know with mine it wont power up unless there is a card in it.
Posted on Jun 22, 2008
It will power up and go to the four digit password and then show four h,s and akey sing then shut off
This camera is a power hog,,,,It sounds as though your batteries are low or one of them may be defective,,,Put some fresh heavy duty alkaline batteries in it and try again...If you have rechargable batteries in it then they may need to be removed and recharged and or upgraded to heavier batteries...I installed 10,000 milliamp/hr batteries and bought a solar panel for mine...It took 74 pictures on Hi resolution last night...
You will have to reset the day and time after removing the batteries...
Dec 29, 2009 | Bushnell Trail Sentry 11-9200 Digital...
NIKON D70 Camera not working after battery change
You may just have two bad batteries, or maybe your charger is bad.
You should have a DC power adapter with the camera, plug that in and see if the camera works longer with it.
You should also have an adapter to use CR02 batteries with the camera. You can buy three of the CR02 batteries at the drugstore (they are NOT rechargeable) and see if the camera works.
If any of these things work, you have bad batterie.
If they don't work, then there is likely some kind of short in the camera and you will need to send it to a service `center or your local camera shop. You might also just take it there and see if they have a known good D70 battery they could try for you.
Jul 14, 2009 | Nikon D70s Digital Camera
Olympus FE170 digital camera shows battery compartment empty with batteries in place I have the same problem. When I place fully recharged batteries in the Olympus FE 170, the camera won't power on at...
on rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Dec 16, 2008 | Olympus FE-170 Digital Camera
Battery fully charged but cannot use camera. Applied new batteries works in review mode only Fuji Fine Piix F420
My camera had a similar problem. It would work only in review mode and as soon as photo/film mode was selected it went dead. What I did was 'discharge' the battery totally and then fully recharged it. This can be done by going to Menu-Option-Setup-Discharge. After I had done this the camera stopped going dead but the battery still had a very poor lifespan. I bought a new battery and now the camera works as new. Hope this helps-Steve.
Aug 16, 2008 | Fuji Cameras
Powers up and then shuts off
This should work for the A520. With NEW or freshly recharged batteries, remove the camera's memory card, then turn on the camera. You'll probably see an E30 error. Next turn off the camera. Next insert the memory card, and turn on the camera.
If the above doesn't work, the following blog outlines some other repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 29, 2007 | Canon PowerShot A520 Digital Camera
I can't turn the camera on anymore
I dont have a definite solution, but I would;
- clean the power contacts on the battery and the camera with a moist Q-tip
- leave the battery out for a day or so, maybe more if you have time. Make sure the battery is charged again (maybe just put it on for an hour or so) and re-try.
Sep 19, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Red light flashing
I had the same problem last night. It went away when I recharged the AA batteries.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Help please
see if keeping the power button pressed continuously without
releasing keeps the camera on
Jun 15, 2006 | Vivitar ViviCam 5340s Digital Camera
Battery problem
It probably lacked the power to retract the lens. I'd start with recharging the battery and see if that corrects the problem.
Sep 19, 2005 | Nikon Coolpix 5400 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
195 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
