Question about JCPenney Basic Crib
Lowering crib mattress
How do i lower the mattress support in a crib - i do not have the type of support that screw in - it has opposing hooks - neither my husband or i can figure it out and we put it together
  • 4 more comments
  • moon1oh Jun 17, 2008
    the crib is about 9 years old - i have no idea who the manufacturer is. my 8-1/2 mos old just started standing up in the crib and i need to lower the mattress support (not the side rail) so she does not climb over and fall (which she almost did last night). there are no springs - the flat wooden mattress support has 4 hooks - 2 which connect to the side supports straight and 2 which connect from the side. I don't remember how to deattach them in order to lower it.
    ours has no screws. its the vertically adjustable using brackets at all 4 corners of the crib which slip into the slot which are attached to the ends of the crib. there are varying slots (about 4) which these brackets slide into. i can't figure out how to remove them from the slots
    i remember it being a bit tricky - slide and pull or lift and pull - it just seems impossible when you look at it - there appears to be no way of getting them out of the slots
    the hooks that go into the front do you lift need to rotate the mattress support up - but how do you release the hooks that are going in from the side (this is worse than a rubic's cube)
    no release mechanism - its a matter of pushing and pulling at the correct location
    Genius:
  • 1,447 Answers
You can loosen it by moving all four slides on the slots at the same time, you should ask help from someone since you cant make it loose if you are working alone. try to check for a lock that might be holding down the slides as well. If you notice that the slides is at the very end of it then chances are there is no option for you to lower it much further, best i got! Thanks!
Posted on Jun 17, 2008
  • 156 Answers
Most cribs feature two or more mattress height adjustments to raise and lower the crib mattress. you can lower the mattress position by depressing the clips that hold the mattress support in place.
do you have such clips in the crib yo use
  • Viv Vek
    Viv Vek Jun 17, 2008
    There must be something for pressing or releasing mechanism for the four brackets from the present slots.. there should surely be one.. find a way to release them and put them in a lower slot
    President:
  • 2,712 Answers
Oh ,how sweet ..9 months is the time to watch out..they are just finding their legs.. I know exactly waht you you mean..my kid is 8 months himself, and he is a bundle..
Just check the louvres (notches) on the side ballasts..if you find any that is lower than where it is positioned at the moment, all you need is monkey wrench and lower the holdings. If you cannot find any other grooves, then I'm afraid, you cannot do it.
But do not fret..if your hubby is handy with woodworking tools, you can make a groove in the ballast/post, exactly where you want it and lower/upper the louvre. If not, seek the assistance of a carpenter, who will be easily able to assist you in about 1/2 hour and get your issue sorted. I do understand that your like to keep the same crib as you've already had it for 9 years, with other siblings occupying it earlier. But this is the only way to resolve the issue.
If you found my answer helpful in any way, or led you to a solution, I request uou to kindly take a moment to "Accept" the solution.
If there is any way I can assist you further, please post back, and I will be more than happy to help you as best I can..
Thanks,
IrishDruid.
  • Swilin Sampson
    Swilin Sampson Jun 17, 2008
    Just unhook them, and see if you have any lower hinges and attach it to them..if you dont, you will have to make one to your specifications, and may require the assistance of a carpenter.
  • Swilin Sampson
    Why not just try asking the manufacturer's themselves or asking from your point of purchase..I'm sure they will be able to assist you better, as they know th make and model of the crib in question..
  • 3,037 Answers
You need to take it apart totally and reassemble it at the correct height. Take a picture of the area with the hooks and email it to me at bestdarntootingood@yahoo.com. I used to assemble cribs at a job I had along with all kinds of things. They are basic so think the simple way always.
If you have any other questions, please ask
    Sergeant:
  • 243 Answers
Underneath there is the mattress support. There should be bolts that all for height adjustment. on all 4 corners there should be a bracket that connects usually to the mattress support. Just loosen those bolts and move it up or down as you see fit.
  • Nathan Ayers
    Nathan Ayers Jun 17, 2008
    here is a link i feel might help you has a diagram of how to adjust a crib. might not be the exact model but it should give you a idea how to do it.
    click here for diagram
    hope this helps,
    Nathan
  • 4,472 Answers
What is the exact make/model of the crib? Did you just purchase it and put it together?
Thanks,
Lee
  • 2 more comments
  • Lee A.
    Lee A. Jun 17, 2008
    Does it have a bumper pad? Have you removed that?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    Mattress Support: Most cribs have a metal mattress support that is held
    by four metal hooks located on all four sides and attached to one of
    the mattress height clips. A metal support will hold up to any active
    jumping toddler, although, the springs might press against the mattress
    and cause tears.
    Release Mechanism: All cribs feature one of three lock release
    mechanisms: metal rods, trigger release and knee release. This is
    important in preventing a toddler from accidentally lowering one of the
    sides and is required by law. Metal Rods, located on either side of the
    rail to hold it in place, allow the rail to move up and down. To lower
    a side, parents must depress the release mechanism usually located in
    the center and on the back of the rail you are lowering. This is the
    nosiest of the three release mechanisms. Trigger Release buttons or
    knobs are located on either side of the rail at the top. A parent must
    depress or pull the buttons/knobs at the same time to lower the
    railing. Knee Release mechanisms require a parent to first lift the
    railing slightly and then push in the railing with your knee. This
    release mechanism is the quietest of the three.
    Hope this helps,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    Does it have sets of hooks going down the length of the crib like 4 sets?
  • Lee A.
    Lee A. Jun 17, 2008
    What is holding the support onto the other part? should be something you have push or pull. You have taken everything out of the crib to do this correct?
    Thanks,
    Lee
How do I lower the mattress?
You have to unscrew the brackets from the front and back or sometimes they are on the sides of the crib and then lower the base. Then you will have to screw them back in
Aug 17, 2010 | Storkcraft Baby Baby Gear
I have a Bright Future for Baby Melanie wooden baby crib (product # 343-7407); how do you unhook the brackets in order to lower the mattress without disassembling the entire crib?
A:You remove the dropside by removing the bumpers and lowering. Then you loosen the screws on th wooden bar under the mattress base without taking apart . If necessary loosen the screws on the frame, but should only be necessary if the mattress base was put in with the straight hooks facing you. In any case you should not need to completely take apart, but still a pain!
Aug 03, 2010 | Toys
Lowering the mattress
I have the same issue... can anyone let us know if you have managed to put the mattress on the lowest (4th hole) setting? PLEASE.
Jul 28, 2010 | DaVinci Emily Crib
I need to lower the base to its lowest setting but not sure how ?
Remove the mattress. in all for corners you should see metal arms that are attached to the mattress support. these arms will be screwed into brackets on the crib. Unscrew all four screws and re-screw them into the lowest hole available. replace mattress and your done.
Jul 10, 2010 | Baby Gear
How do I lower the mattress on my Bonavita crib quickly?
Most cribs have tabs on the rails of them .... take everything out .. bedding,mattress,etc. Take a look at the platform that the mattress lays in especially the corners.... You might see a hook at each corner that fits into a release tab unlock the realease tab and remove the hook. Do this for each side and reinsert the hooks at the correct level in the crib... If this is not the case you may need to look at the owners manual... But I think you should be able to get a good idea about how it lowers when you remove all the bedding out of the crib..... good luck
Oct 19, 2009 | Bonavita Peyton Crib
Lowering the Mattress
Call LaJobi (the manufacturer) and ask.
LaJobi 877-440-2224
Jan 19, 2009 | Graco Lauren Crib
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
Childesigns carrollton crib
I am not familiar with this crib, but I have been through many cribs and they all (so far) are adjustable to lower the mattress. You can figure it out by removing the mattress and matress board and inspecting the way the board is connected to the frame. Often there is a bar or rung that sits in a clip or groove at each corner of the crib just below the matress board. You may have to crawl underneath and look up at it. Usually you will be able to lower the platform without using tools, but be sure to take the weight off the platform by removing the mattress and board. Good luck.
Nov 14, 2006 | Childesigns Carrollton Crib
JCPenney Basic Crib Logo
535 people viewed this question
Top JCPenney Baby Gear Experts
Lyle Siemens
Lyle Siemens
Tom Chichester
Are you a JCPenney Baby Gear Expert? Answer questions, earn points and help others
