Question about Maytag Neptune MAH6700A Front Load Washer
Door is locked, No power to machine. Checked breaker. Manual said to check fuse, don't know where fuse is.
  • 33 Answers
It should be on the back side of the machine by your timer
Posted on Nov 10, 2010
2007 chevy silverado power window dome light and power mirror passenger side front
Beings as everything that stopped working is on the passenger side, I'd think some wiring got disconnected or broken.
Jan 14, 2014 | Cars & Trucks
2001 olds aurora, no power to passenger side window modules..plugged them into driverside doors they work.. also tried pass. side window motors on d.s and they work fine, any idea on what wire is power....
If the driver window works, the 30A PWR WDO CB and the 10A DRVMDL fuse in the rear fuse block must be OK. The passenger window gets power from the 10A PASS MDL fuse and that should be checked. The rear windows get power from the 10A RRDR MDL fuse and that, too, should be checked. The same circuit breaker and fuses protect the door locks so replacement of the burned out fuses should clear up your problem
Oct 28, 2012 | 2001 Oldsmobile Aurora
1998 dodge durango. both the power windows and door locks stopped working. any suggestions?
They are on two different circuits. The windows are on a 25amp circuit breaker, and the door locks are on a 20amp fuse.
The door locks go thru a central timer module but the windows don't.
Have you checked for power and ground at the driver's door switch ?
Aug 11, 2012 | 1998 Dodge Durango
Drivers side power door lock
I would test the wiring with a voltmeter to see if you have a short or bad circuit
Jun 06, 2012 | 2006 Pontiac Montana SV6
Washer won't start
could bea wide range of items since we don't have any description at all. does it have a display when you turn on or is it blank? does the door lock buzz or appear to be locking door. is it totally dead and have you checked power at plug to make sure a breaker hasnt tripped. the control assemblies on these are fragile and could be bad ,but before stating that need more info...
Dec 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Sunroof will not work
Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
The RAP relay is responsible for the radio and windows working after the igntion is turned off.
The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
(7) Door Lock Relay
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
Jul 10, 2010 | 2000 Chevrolet Blazer
Maytag Neptune MAH6700A Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
