Question about HP Photosmart 4180 All-in-One Printer
Can't scan with hp4180 - HP Photosmart 4180 All-in-One Printer
  • HP Master
  • 7,733 Answers
Using HP4180 on windows 7. When I scan it saves file on letter size format. How can I crop or change scan size befor saving?
you might need to change the settings on the document/s letters before scanning depending on which program you are using to make this document ?
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
if you need more help with this post a reply
hope this helps
Aug 16, 2011 | Computers & Internet
Router is secure, but cannot connect to wireless . Get error that SSID failed when I run printer test. It is a HP4180.
There is a chance that the wireless device on the printer can not process SSID's with spaces in them.
Also the wireless device may not be compatible with the type of security used on the router. So try changing the wireless security settings on the router as well.
Feb 24, 2011 | Linksys Wireless-G WRT54G Router
Can the hp4180 run with just the black ink cartridge filled with ink and not the color cartridge
no, I don't think that it is recommended to run with just the black ink cartridge filled and no color cartridge.
But, you can try it, as some hp printers do work that way.
The instructions say that low ink cartridges should be replaced to get the best print quality.
Jan 01, 2011 | HP Photosmart 4180 All-in-One Printer
I can print word processing documents and off the web, but I can no longer print databases. I have several small databases, which I could once print in Landscape. Now I get an instant "out of memory"...
Best Solution posted 2 years ago
5986a52.jpg CompuGuy44
  • Rank: Wiz hp.gif computers_small.png
  • Rating: 82%, 1025 Votes
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works
Aug 29, 2010 | HP DeskJet F380 All-In-One Printer
Have a HP4180 deskjet printer that also scans. How to get images in the computrer?
The user manual that came with the printer should explain how to do this.
See extract below
Scan an image
You can start a scan from your computer or from the HP All-in-One. This section
explains how to scan from the control panel of the HP All-in-One only.
To use the scan features, the HP All-in-One and computer must be connected and
turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software
(Mac) must also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the
Windows system tray (at the lower right side of the screen, near the time) to verify
the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows
system tray can cause the HP All-in-One to lose some of its scan
functionality. If this happens, you can restore full functionality by restarting
your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart
Mac Software (Mac) to scan images, including panorama images. Using this
software, you can also edit, print, and even share your scanned images. For
more information, see the onscreen Help that came with the HP All-in-One.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Start Scan.
3. Press OK to select the default application to receive the scan, or press to
select a different application, and then press OK.
A preview image of the scan appears on your computer, where you can edit it.
4. Make any edits to the preview image, and then click Accept when you are
finished.
Dec 19, 2009 | HP Office Equipment & Supplies
Can not scan
You will need to chk for the scanner drivers if they are installed properly in the scanners in the control panel.....but before scanning something try copying from the machine,it will help you to isolate the issue from a hardware issue.....if the drivers are there uninstall and reinstall the drivers from the device manager......also install the hp solution centre s/w from the cd that came with the printer.....
Jun 24, 2009 | HP Photosmart 4180 All-in-One Printer
Printer "out of memory"
Let me know if this works.
Feb 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
So which printer are you wanting help with?
Nov 23, 2008 | Office Equipment & Supplies
a reasonable fix for microsoft is for you to spend $40
Aug 15, 2008 | HP Photosmart 4180 All-in-One Printer
Scanner will not save to computer
By default, the HP all-in-one sends all scans to the HP Photo & Imaging Gallery for you to preview. Suppose that you want to scan your photos directly to email instead. To do this you will need to modify the destination assigned to the front panel scan button. Here is how to do it:
  1. If you have not already done so, open the HP Director and click Settings , point to Scan Settings & Preferences , and click Scan to… Setup . The Button Settings dialog box appears, with the Destination List tab on top. The HP all-in-one automatically inventories your computer and lists all the possible scan destinations for you in the Available Scan Destinations list.
  2. Using our example of scanning directly to email, select the Email destination in the Front Panel Destination List and click the Move arrow to move it to the top of the listing.
  3. Click OK to save the new destination setting and close the dialog box. All of the scans you do using the HP all-in-one front panel buttons will now be sent directly to your email program, instead of to the HP Photo & Imaging Gallery.
  4. Click Scan Picture or Scan Document in the HP Director to scan using your new settings, or click a Scan button on the HP all-in-one front panel.
also
Setting a default scan profile Use the following steps to apply a scan profile to all future scans.
  1. If you have not already done so, open the HP Director and click Settings , and click Scan Settings and Preferences .
  2. Click one of the following, depending on the type of scan profile:
    • Scan Picture Settings
    • Scan Document Settings
    • Button Settings The corresponding dialog box appears. If you chose Scan Picture Settings or Scan Document Settings , the Scan Settings tab is on top. If you chose Button Settings , the Scan Button tab is on top. All of these tabs have the setting you need, Apply Scan Profile .
  3. On the Scan Settings or Scan Button tab, click Apply Scan Profile and select the scan profile that you want.
  4. Click OK . The scan profile that you selected will apply to all future scans for the scan type that you selected.
Apr 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart 4180 All-in-One Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
