Question about Norelco 20XL Clipper Hair Trimmer
Need a new battery for the norelco 20xl rechargeable trimmer
hmosoff
SOURCE: I have a Norelco Accuvac T770 trimmer that will not hold a charge
I did everything possible to find help as I did not accept the answer from Norelco. They told me that there is no way to change the battery except by a qualified repair shop. I made them admit that they basically made a consumable device so they can get you to buy new shavers in the future - in so many words.
I finally pried the thing open as carefully as I could. Once opened, you will find 2 batteries glued together. They are Ni-Cd 2,4 volt - 600 mAh batteries. Looking all over, the only store that helped me was Battery Plus. There are stores all over the country storeloc
.aspx">http://www.batteriesplus.com/t-storeloc.aspx .
They sold me two 1.2v 1000mAh batteries for $3.50 each. For another $5 they spot welded them together with tabs for soldering the 2 wires on.
Okay, after getting the new batteries, I went back to my old batteries and slowly pried the tabs of the top. They pretty much snap off as they are only slightly tap welded on.
I then took out my model soldering gun and with a little patience, soldered the two wires on to the new leads on the new batteries.
Within minutes, I had the thing put back together and charging. It works great and now I can tell all of those who said it can't be done - or those who wanted $40 to refurbish it, to go scratch - I GOT MY SHAVER BACK!!!!
We all need to learn to stop living in a consumable world. I have a feeling due to the economy we are facing, we will all try to save money in this manner.
Good Luck!!!
Posted on Dec 30, 2008
evwood
  • 50 Answers
SOURCE: I believe my Ryobi 12 VoltBattery Line trimmer need a new battery
First, check to see if the charger is working properly. To do this, recharge the battery for about 15 minutes. Then check to see if it now runs the trimmer. If so, then you have a bad battery. You can go on the WEB and find a replacement. These batteries or sensitive to heat and cold. When storing, try to place it in a comfortable environment. Sorry for your loss. If it still under warranty, check with the Co.
Posted on Jan 03, 2009
  • 5 Answers
SOURCE: Norelco model 5885 XL Battery replacments
I just installed two brand new Eneloop cells and it will only charge up to 35 minutes on the display (I had been able to get up to 52 minutes with the original NI-CAD's). I also discovered that it would not recognize the capactiy on the minute meter until I drained the batteries and recharged the unit. When I went to drain the batteries they ran for 2 hours and 15 minutes!!! But again the display only shows 35 minutes right now after an hour charge when it says FULL. I'll leave it on the charger and see what happens. I used a pair of needle nose pliers and "rolled" the metal tabs off the NI-CAD's. Snapped the one on the negative side but got the positive side off clean. I couldn't get the strips to solder back to the new Eneloop batteries so I had to use electrical tape which seems to be holding fine. The battery holder holds the positive and negative terminals against the old tabs just fine. Also I learned that if you hold the power button on long enough it will cycle through a test function. It will go to zero minutes and all the way up to 35, then turn on and go back to zero stopping at the appropriate cleaning cycle times (takes about 40 seconds to do the test so don't touch the power button until it's done). Not sure if the batteries will still go 2 hours and 15 minutes after being charged in the shaver, but they do when chaqrged outside the shaver. Just my two cents!
Posted on Aug 23, 2009
SOURCE: Norelco shaver 800RX The spring on the pop-up trimmer came out
The spring has two coils, one at each end. They need to be pushed, hard, into the plastic tabs. I heard each side 'click' in. I wasn't pushing hard enough at first.
Posted on Aug 30, 2009
SOURCE: I recently purchased the G370 Norelco hair
S.O.B! Just bought the bastard 3 weeks ago after I had another one before it that didn't last even a month. THEY WON'T CHARGE A BIT!!! The damn light glows as if it's charging but the device never turns back on. This damn company can GO TO HELL!!
Posted on Aug 24, 2010
Where is the battery
the battery in side the shaver
Jul 16, 2014 | Norelco 20XL Clipper Hair Trimmer
Phillips norelco nose and ear hair trimmer
If it is battery powered then the battery is probably flat. If the batteries are rechargeable then check the charger and if alkaline then get new one/s
Jul 18, 2013 | Philips Norelco NT9105 Nose and Ear Hair...
How do I change the batteries in my Norelco 3805 XL rechargable shaver?
You will find the correct battery type for model 3805XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the 4 screws. You may need to extend the long hair trimmer to get to two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Nov 22, 2010 | Norelco 3805 XL Electric Shaver
How to remove rechargeable battery for norelco 7864
hi minglim, welocme to the forum!
    Replacing a Norelco Shaver Battery Things You'll Need:Torx screwdriver set Rechargeable Ni-Cd AA battery 1)Slide up the sideburns trimmer on the shaver .2)Try the various torx head screwdriver sizes to find the fit for the two screws holding the top of the back shaver cover on. Unscrew the two screws that are under the sideburns trimmer that hold the back of the shaver on. On some Norelco shavers, the back will now slide off if you apply downward pressure on the shaver's back. Other Norelco shavers have one or two torx screws on the base of the back cover on the shaver; if so, unscrew them also. Place the screws in a safe place. 3)Take the back cover off the shaver. Some shavers may have a strap fastening the battery down. Unfasten the strap if there is one. Take out the battery. 4)Replace the old battery with a new rechargeable Ni-Cd AA battery. Re-fasten the battery holding strap if there was one. 5)Replace the back shaver cover and re-screw in all the torx screws,
May 20, 2010 | Norelco 7800XLCC Electric Shaver
I finally pried the thing open as carefully as I could. Once opened, you will find 2 batteries glued together. They are Ni-Cd 2,4 volt - 600 mAh batteries. Looking all over, the only store that helped me was Battery Plus. There are stores all over the country storeloc.aspx">http://www.batteriesplus.com/t-storeloc.aspx .
Good Luck!!!
Dec 15, 2008 | Norelco T770 Beard Trimmer
Health & Beauty Logo
271 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
