Question about ASUS P4VP-MX Motherboard
Windows cannot startup, it said "press Del to run setup"
  • ASUS Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
Posted on Nov 10, 2010
My satellite Toshiba L875D-s7230 says bootmgr is missing press ctrl alt and delete to restart and does nothing
Which operating you are using?
Method 1: Run Startup Repair from Windows Recovery Environment (WinRE) To run Startup Repair from the Windows Recovery Environment (WinRE), follow these steps:
  1. Insert the Windows installation disc into the disc drive, and then start the computer.
  2. Press a key when the messagePress any key to boot from CD or DVDappears.
    If your PC does not detect the media automatically
    1. During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
    2. Look for a tab in the BIOS Setup Utility that is labeledBoot Order,Boot Options, orBoot. Following the directions on the screen, use the arrow keys to go to theBoot Order, then press Enter.
    3. Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYes in the confirmation window. The PC will restart.
  3. Select a language, a time and a currency, a keyboard or input method, and then clickNext.
  4. ClickRepair your computer.
  5. In theSystem Recovery Optionsdialog box, select the drive of your Windows installation, and then clickNext.
  6. At theSystem Recovery Optionsdialog box, clickRepair your computer.
  7. Click the operating system that you want to repair, and then clickNext.
  8. In theSystem Recovery Optionsdialog box, clickStartup Repair.
Method 2: Rebuild the boot configuration data (BCD) from Windows Recovery Environment (WinRE)
  1. Put the Windows installation disc in the disc drive, and then start the computer.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYesin the confirmation window. The PC will restart. Allow the PC to restart normally. The scan will take a few minutes and remove any malware that may be infecting your computer.
  3. Select a language, a time, a currency, a keyboard or another input method, and then clickNext.
  5. Click the operating system that you want to repair, and then clickNext.
  6. In theSystem Recovery Optionsdialog box, clickCommand Prompt.
  7. TypeBootrec /RebuildBcd, and then pressENTER.
Jan 20, 2017 | Toshiba Computers & Internet
Press DEL to enter Setup, Press TAB to display BIOS POST message"
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2V&p=1&s=24
Try to download the manual, by selecting your windows system.
Open the manual folder, and click on global for download.
You might need to upgrade the bios, to support windows 7, and certain harddrives.
You also need at least 2 gb ram, for the install.
Good luck
Jan 25, 2013 | ASUS M2V Motherboard
to install window7 just put dvd in tray startup computer do what it says to do asn question
Can't resme windows
Try to go into setup and reset to factory defaults. Most likely you have some damaged system files. If this is the case, you will need your windows disk. Boot off of that disk and run the repair process to repair all of your critical system files.
Sep 22, 2012 | Computers & Internet
I have an Asus Eee PC 1001ha series, with Windows XP. Whenever I turn it on it displays the grey asus screen with the phrase "press F2 to run Setup, Press TAB to display BIOS POST Message",...
My suggestion is better to send it on the technical around on your area, to prevent any further damage. And also backup your files by removing your hard disk and slave it to other computer. Just use any converter of mobile hard disk to become a USB type drive. Hope it helps thanks.
Sep 21, 2011 | ASUS Eee PC 1000HE Netbook
I have an acer aspire one notebook any time i tur on the laptop appears "BOOTMGR is missing press Ctrl+Alt+Del to restar" . I restrted but the same message appears again.. help plz
No work around. The system cant find the operating system. Make sure the CD is empty though!!!
if it was. You need to reinstall windows
cheers
rebe
May 28, 2011 | Acer Aspire One PC Notebook
My setup is saying that there is a file named "dwtrig20.exe" is not found what should i do???
During start up your computer is trying to start the Dr Watsom program -but is for some reason not able to do it - file missing.
below is instruction how to remove Dr Watson from start up.
  • Click the Windows "Start" button and click "Run." Type "msconfig" (without quotes) and press "Enter" to open the System Configuration Utility window.
  • Click the "Startup" tab. Scroll through and click "dwtrig20.exe" and click "OK." Restart your computer. The program will be removed from startup and will no longer run.
  • Read more: How to Remove DWTRIG20.Exe ' eHow.com http://www.ehow.com/how_5201929_remove-dwtrigexe.html#ixzz1FAJOPU00 Click the "Startup" tab. Scroll through and click "dwtrig20.exe" and click "OK." Restart your computer. The program will be removed from startup and will no longer run.
    Feb 27, 2011 | Computers & Internet
    I start up my computer and i get a black screen that says "NTLDR is missing Press Ctrl+Alt+Del to restart" at the startup screen pressing f10 doesn't bring up system recovery and I don't have...
    what is the model of your computer,? if the recovery software is in a hidden partition there must be a way to access it from boot, otherwise, you will have to buy a windows disk and reinstall windows.
    Feb 05, 2011 | Microsoft Windows XP Media Center Edition...
    Dosnt go into window. stys black with words flashing
    REMOVE ANY EXTERNAL ATTACHMENTS [PRINTER,SCANNER,PEN DRIVES ETC.] SEE IF IT STARTS.AND BY ATTACHING THEM ONE BY ONE YOU WILL KNOW WHAT'S PROBABLY WRONG. IF IT DOESN'T START PRESS F8 AT STARTUP AND SELECT "LAST KNOWN GOOD CONFIGURATION" FROM THE ADVANCED OPTIONS. YOU CAN ALSO PRESS DEL. AT STARTUP AND IN THE BIOS SELECT "LOAD SETUP DEFAULTS" IF ALL OF THESE WON'T HELP THE LAST OPTION REMAINS INSTALLING WINDOWS AGAIN. HOPE IT HELPED.
    Jul 19, 2009 | HP Pavilion dv8000z Notebook
    NTLDR is missing
    You need to reinstall your xp or use the restore cds /dvds that came with the laptop to repair the windows startup problem.
    Files missing / corrupt.
    May 08, 2008 | Acer Aspire 5100 Notebook
    ASUS P4VP-MX Motherboard Logo
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
