Question about Canon FAX-L360 Plain Paper Laser
Output tray full Fax L-360 - Canon FAX-L360 Plain Paper Laser
Unload output tray
The Tray Full indicator lights on the appropriate stacker tray
(applies to dual stacker only).
A message displays on the printer control console that
indicates which output tray is full.
In automatic switching mode, the system automatically
switches over to the second tray (if it is empty) when one
tray is full (applies to the dual stacker only).
If only one tray was selected or if both output trays are full,
the printer stops.
The picture on the graphic display shows the location of the
full tray.
Still having Problem Then follow Us For
Brother Printer Support
Feb 11, 2014 | Brother HL 2700CN Laser Printer
My photocopier (Canon iR1600) displays a message that the output tray is full when i try to photocopy
hi . check the flag sensor in the output tray . if you move the flag sensor up it should come down when you loose it
Mar 06, 2013 | Canon iR 1600 Copier
Machine is saying "output tray full" no faxes
Open the fax. There is a small door that allows access to the fuser for jams. There is a little black tab to the right on the door. Reseat it so it is level and pivots freely. Close up machine should start faxing. This tab is a flag for a photointerupter. Is easily knocked out nof place.
Feb 17, 2011 | Canon LaserClass 2050 Plain Paper Fax
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Fax output error
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes sucessfully or you can put paper in the cassette tray...
Hope that helps.
Mar 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Xerox ColorCube 9201 fax output tray change
Yes. If you press the login key( admin : 1111) then hit machine status(left side) there is a tab on the touch screen that says tools. If you go under fax settings or default fax settings it will be a option labeled as output destination. You can also find these setting if you type in the ip address of the mfp in your web brouser (same user name and password required). Hope this helps!
Jan 04, 2010 | Canon LaserClass 2060P Plain Paper Fax
OUTPUT TRAY FULL
If you open the cover,the same cover you open to replace the toner.There is a guide that can swing up and down.This sensor is situated in this guide.Swing this giude to the down possition and you will see the arm that actuate the sensor.Make sure this arm is in the correct possition and can swing up and backwards.Some time this arm get stucked against the body of the fax.It normally hapened when the upper cover of the fax was removed.
I believe you can fix this one, it is a relative easy fault
Dec 08, 2008 | Canon CFX-L4000 Plain Paper Laser Fax
Output tray
In the Admin section, there are areas to specify output trays.
It is either in the paper tray area or the fax and print setup.
It can deffinately be done, depending on the model as to where it is.
Sep 10, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Hey
check where the paper comes out after a copy or fax, there is a lever ( sensor ) there, it is most likely stuck in the up position, it should be able to go down after each print. "output tray full means there is too much paper in the output bin you need to remove it before continuing to print.
Jan 24, 2008 | Canon LaserClass 2060P Plain Paper Fax
Output tray is full
Hi, there must be an actuator of the output tray sensor.It is placed above paper tray, just in place when paper exit from machine.Try to clean sensor,or to place actuator in proper place-pull it down.Also,maybe is actuator broken.
Apr 03, 2007 | Xerox Phaser 7700DN Laser Printer
Canon FAX-L360 Plain Paper Laser Logo
61 people viewed this question
old marine
old marine
