Question about Canon Pixma iP2600 Photo InkJet Printer
I have a canon ip2600 printer and i just refilled the ink cart. and it still says my ink is low. i ran the proper tests and it still says it. is there anything i can do
    Welcome Back:
    Visited the website for 2 consecutive days.
Hold down (most forward) paper feed button (yellow light) for about 30 seconds. Ink minder function will be turned off, and will no longer moniter ink level.
Posted on Nov 21, 2010
  • emelek Nov 21, 2010
Black ink volume unknown
Problem is you refilled the cart and didn't reset it properly so it looks like a new cart, check your other carts and see if gears or holes are wrong.
Nov 26, 2013 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma ip2600 cartridge not installed properly
Please check if there is not some dirt, or something blocking the contacts from reading. Also the ink level is measured by optical sensor that can also be dirty. Also make sure you use an Original Canon cartridge. It could be the chip on the cartridge has either gone bad or could no longer be reset. The chip is what tells the printer that it is ok to print (i.e. there is ink available and that the cartridge is approved). Some chips will only be reset with available procedures a few times. Other times refillers are not succesful in resetting the chip or just give you another cartridge that is already refilled and could just happen to have a bad chip. You should probably return the cartridge and try to get one that will work based on the argument that refilling is not only related to ink but also to chip. Otherwise here is a web site that has a special page for your Pixma that contains all possible refill products: http://www.inkfilling.com/inkjet-refill-... Source(s): http://www.tonerguru.com
Aug 07, 2012 | Canon Pixma iP2600 Photo InkJet Printer
Canon iP2600 Printer yellow light flaxes message says an ink cartridge is not installed properly
have you tried cleaning the printheads ?
There is an option for cleaning head in printer's properties : select this and you will be able to clean printehads for the canon iP2600
Jan 19, 2012 | Canon Pixma iP2600 Photo InkJet Printer
I have the ip2600 and i just put 2 new ink cartridges in it but it is not recognizing that they are refilled and is stating that they are low and it will not print. My old printer would ask if they have...
Hi
Is there an ink resetter in your printer, reset the ink to dectect to detect the ink cartridge.
If not clean the chipset of the ink cartridge by using cloth will alcohol or warm water.
Also turn off your printer for 5 mins and put again the cartridge.
I hope it helps you.
Jan 13, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Please how can i refill a canon printer's cartridge (canon pixma ip2600), without the ink pouring out through the other end
Place the empty PG-30 cartridge on a layer of paper towels on a flat surface.
Use the thumb screwdriver to enlarge the small refill hole just below the letter "B" on the top of the cartridge.
Fill the syringe with 20 ml. of black printer ink.
Slowly insert the syringe into the refill hole that you drilled and release the contents of the syringe.
5
Allow the cartridge to sit upright for 4 hours before inserting into the printer.
Easy!
~KenjiFox
Jan 07, 2011 | Canon Pixma iP2600 Photo InkJet Printer
We ran out of ink and we decided to refill the ink cartridge...At the first time of refilling it, it was still working...But then when we ran out of ink again for the second time we refilled it again...but...
u cant the printer must detect the cartriges are full using calibrated incss. if this does not work as it has not the printer wont work sorry its time to puy in new genuine print carts
Jun 24, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Changing ink cartridges
If you have put in genuine Canon cartridges, contact Canon support for advice.
If you have refilled in any other way, your printer cannot detect ink levels. If you have used a refill kit, you might have problems if you return your printer for repair under warranty as evidence of refilling is the first thing checked for
Apr 09, 2010 | Canon Pixma iP2600 Photo InkJet Printer
I dont know how to refill my canon ip2600 ink cartridge
Problem is resetting the IC chip that they install that calculates that your cartridge is empty, Refilling it doesn't work because the chip tells the printer that it'S empty. No way to reset it yet.
Oct 07, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
1,269 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
