Question about Dell Dimension 4600 PC Desktop
Keep getting checkpoint errors, and have changed Sys Battery , reset Bios and when i boot it ,it goes to Dell logo and keeps trying to reboot. Windows will not load.
    Guru:
  • 610 Answers
Try going to the BIOS and see if it reboots from there. If it does, then it is most probably a hardware problem. You can try re-seating the memory modules and If you have multiple modules, try them one at a time.
If it does not reboot while you are in the BIOS, then the problem lies on Windows. Get your DELL Restore CD or your Operating System CD and insert it to the CD-ROM drive. Reboot the computer and press F12 while seeing the Dell logo, that should give you the options to boot to CD-ROM. It will give you a quick prompt of "press any key to boot to cd..". Make sure you press the space bar during this time to initiate the boot from CD-ROM.
Once the Windows Setup loads, Choose "Recovery Console" to repair your computer. Just choose the installation you would like to repair (normally it's number 1) then it will ask you for the administrator password. By default, the password is blank, but if you set a password for admin then use that password.
Once you get to the prompt, Type this command. "CHKDSK /R" (without the quotes). It will initiate the repair for your OS. This might take an hour or so. Just wait for it to finish and it will automatically reboot your computer. Let the computer computer reboot normally. You should be able to get to your normal windows screen back.
Good Luck.
Posted on Nov 10, 2010
Laptop says no boot device found
Hard drive has failed, bios is drained or boot order was changed. When you start it there should be a message that says to press a certain key to enter setup, press that key and then look for the date and time, if it is good look for hard drive info. If it is not there then the drive is bad
Sep 15, 2015 | Dell Computers & Internet
My dell laptop keeps going back and forth from the loading logo screen to black screen
You might like to Power it off completely by removing the Battery for a few seconds.
If that doesn't help, try booting from your Win7 Installation Disk.
Apr 28, 2014 | Dell Studio 1537 Laptop
Dell Vostro 200 goes straight to analog mode/sleep, keyboard, mouse not responding; not booting
replace bios battery, reset the bios, insert required parameters after rebooting and when windows reboot change the time period for screen saver and hard disk shut down!
Aug 05, 2012 | Dell Vostro 200 PC Desktop
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
Boot failure at USBd checkpoint
There are 2 steps you can do to fix the problem
1. Change the USB Emulation Setting in the BIOS
NOTE: It is recommended to disconnect any USB devices before performing the following steps.
Restart the system.
Wait until the Dell Logo appears.
At the Dell Logo screen, press F2 right away to enter the System Setup.
The System Setup screen will appear.
Press the down arrow key to highlight Integrated Devices (LegacySelect Options).
Press Enter.
A small box with a list of devices appears in the middle of the screen.
Press the down arrow key to highlight USB Emulation.
The default setting is On.
Press the Space Bar on your keyboard to change the setting to No Boot.
Press the Esc key.
The small box disappears.
Press the Esc key again.
A small box with list of options appears in the middle of the screen.
Make sure that Save Changes and Exit is highlighted in blue.
Press Enter.
The system will then restart.
The recommended changes have now been made to the BIOS.
2. Reset the Dell Dimension desktop System Setup (BIOS) to factory defaults.
Restart the system.
The Dell logo screen appears.
Press F2 to enter the System Setup (BIOS).
The System Setup screen appears.
Press the ALT + F key combination.
Press the Esc key to Save and Exit.
Press Enter to Save changes and exit now.
The BIOS is now set to the default settings.
Apr 02, 2009 | Dell Dimension 3000® Pentium® 4...
My dell dimension 8400 bios a03 fails to bootup and displays this alert on the screen: Many attempts to boot the system have failed at checkpoint [Ithr]. how can i recover from this?
You need to reset your bios settings. Open your case and remove the cmos battery for 10 minutes. Caution: unplug all ac plugs before you open your case. put the battery back in and turn it on you should see an error message saying: you need to set system time and date. If you see this then you have successfully reset your bios settings and the defaults should load up. follow the instructions to change your time and date settings and save. reboot and hopefully you can boot up. I hope this works.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Boot problems,have to hit F1 to boot to windows
Can you get it to go into windows at all?
Did you actually change the CPU?
When it says to hit F1, keep hitting it repeatedly, you will kow it acepted it when you hear a little beep from the P.C. Case
then it should go into bios. if not, then it may not be recongnizing the keyboard.
typically this issue occures because the internal clock is off do to apower shortage or the Bios battery has dies. Its a little watch battery on the system board. If you can get into windows, check the date and time, set it and it should sync the bios clock.
Let me know how it goes.
Feb 04, 2009 | Dell Dimension 3100 PC Desktop
Motherboard
Sounds like you tried everything except reseating any other hardware that may or may not be placed in another socket such as PCI, AGP, etc... Like a Modem, Network adapter, Sound/Graphics card, Wireless card, etc... This is probably a wasted post as if you knew to check each stick of memory seperatly then you've probably already reseated all socketed hardware. Though, you could remove all non essential hardware such as I mentioned above and try installing Windows again?
Good luck and keep us posted.
Sep 06, 2008 | Dell Dimension 8400 PC Desktop
NIC error/keyboard fuse failed
hear what u can do u can try resetting the bios or taking out the cmos battery for like 30 to 45 mins and the error u r getting will go away but if the NIC error keep accuring well there a problem with yr network card and for the hard drive when the pc is now booting up all dell normally comes with a testing device tool to get this testing device u can press F2 on when yr pc now going throught the post and just select hard drive testing...if it fines an error with the hard drive well u need to replace it....ok let me now if that work.
Dec 19, 2007 | Dell Dimension 2400 PC Desktop
Dell Dimension 4600 PC Desktop Logo
102 people viewed this question
Alun Cox
