Question about GE WDSR2080D Top Load Washer
It just keeps filling and overflowing and won't wash. My husband just bought a new control panal but it didn't solve the problem
  • 4,070 Answers
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Posted on Nov 10, 2010
My husband installed a belt in our Maytag washer model #sav205daww. when I went to use it it filled with water and didn't stop, it overflowed. Any ideas what might be wrong?
He could have pulled the small hose off that connects to the water level switch.
Or sediment could have shifted when he tilted the tub. Check that hose for secure connection and blow threw it to move the sediment and then pump out the water so that the pressure can build once again from the water level switch down to the base of the tub. themobilian_2693.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 27, 2011 | Washing Machines
The washer overflowed as it was filling up, as if it didn't know when to stop, never agitated, just started leaking everywhere all over the floor!!
Your overflow pressure switch did not work properly either because it is faulty or the hose to it is disconnected. I would start by checking the hose connection. The hose gos from the outside of the tub up to the control panel where the switch is located.
Jun 02, 2011 | Washing Machines
The washing machine drum keeps on filling up with cold water, we have to keep on emptying it cause it overflows. door won't close either.
This is symptomatic of a malfunctioning cold water control valve, particularly if it happens with POWER OFF.
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 05, 2011 | Washing Machines
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Top loader washer won't fill with water
Either the water level sensor is faulty or the selector switch is bad.
Servicing the Water Level Control Switch
This is another control panel switch, usually located next to the temperature switch. There is a small hose connected to this switch, and sometimes this hose becomes loose and falls off the connection. When this happens, the water in the tub usually overflows. To solve this problem, cut about 1/2 inch off the end of the hose and use a push fit to reconnect it to the switch.
The switch itself can also malfunction, resulting in tub overflow and other water-level trouble in the tub. If you suspect this switch is faulty, remove it by backing out the screws holding it in place. Take it to a professional service person for testing. If the switch is faulty, replace it with a new one of the same size and type. Connect the new switch the same way the old one was connected.
Oct 01, 2009 | Washing Machines
Smartdrive 051 wont stop filling
HI Servicing the Water Level Control Switch
The switch itself can also malfunction, resulting in tub overflow and other water-level trouble in the tub. If you suspect this switch is faulty, remove it by backing out the screws holding it in place. Take it to a professional service person for testing. If the switch is faulty, replace it with a new one of the same size and type. Connect the new switch the same way the old one was connected..PLEASE RATE IT......
Nov 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Our washing machine keeps filling with water and overflows. It will not stop filling with water no matter what setting it is on.
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Apr 26, 2008 | Washing Machines
GE WDSR2080D Top Load Washer Logo
48 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
