Question about Dryers
When trying to start the dryer, the heating element inside will come on but the drum will not turn. Could this be as simple as a blown fuse? Has the motor failed?
  • 33 Answers
First check your belt and if thats not it then listen for a humming sound if thats the case then your tranny is locked up
Posted on Nov 10, 2010
Lg dryer fuse keeps blowing but the heating element and thermostat all have continuity
I have been using an LG domestic dryer in a commercial application (motel) for 5 years and the only problem has been a lint build up inside the dryer because of an improper vent installation. The problem is likely in the dryer drum motor, it runs for a short time heats up because of bad motor bearings, improper motor cooling or bad drum bearings (motor drives the drum) increased heat = increased amperage= blown fuse. Motor should go out on overload but it may blow a fuse first. Is the fuse in the electrical panel or in the dryer? Try turning the dryer drum by hand and check for resistance, there shouldn't be much. The motor needs to cool so pull the dryer panels apart and vacuum the inside first and make sure the motor and interior has been thoroughly cleaned. Try this for a quick fix first.
Jan 31, 2015 | LG DLE3777 Electric Dryer
I have a Kenmore 90 series dryer, drum turns but will not heat up.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 25, 2011 | Kenmore Dryers
Unit will not heat up. Drum turns
Jan 23, 2011 | Dryers
No heat , drum turns and wont shut off
Hi, On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 05, 2010 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool dryer Model # LGR7648K20 that just stopped heating. THE DRUM TURNS BUT IT WILL NOT HEAT.
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to Good luck
Regards:
VOTIT
Dont forget to rate:
Jul 01, 2009 | Whirlpool Dryers
Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Apr 27, 2009 | Dryers
GE Profile Harmony Dryer DPGT750EC Drum won't turn & no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Jul 04, 2008 | GE Profile Harmony DPGT750EC Electric...
Estate gas dryer
Heating element
Thermal fuse
Wiring
Jul 04, 2008 | Estate TGDS840JQ Gas Dryer
Kenmore 62822 electric dryer
Check your heating element to see if it is shorted to ground.
The element has 110V to it all the time, so if the element shorts to ground it will heat all the time. This is a fairly common failure.
If the element is ok, you may have a stuck centrifigul switch inside the motor, this is very rare but does happen sometimes.
Post back to let me know what you find or if you have any questions.
Thanks/Mike
Dec 20, 2007 | Kenmore 62822 Electric Dryer
Dryers Logo
24 people viewed this question
Top Dryers Experts
