Question about Compaq Keyboard
I clicked num lock then clicked it again and it wont turn off ! i have an older computer so Fn is not an option
  • 2,973 Answers
Reboot the device and stop using the numlock. Instead use the numbers on top. The key seems to have got stuck. Or on second thought, try the sophisticated technique of putting the keyboard/laptop upside down and tap lightly on the back cover to release the stuck key. Works sometimes. But tap very lightly.
Posted on Nov 10, 2010
    Guru:
  • 2,178 Answers
Try using the "On-Screen" keyboard in Windows.
I have a Mac computer and the key board Num Lock won't turn off. I tried Fn=Shift+NumLock or Fn=NumLock but still won't unlock, Help
Hi Kip,
On the right side of the number keypad on a Mac Laptop, there is a 'Clear' button above the number 7. Press Shift + Clear to turn Num Lock on. Press that again to turn it off. If the keyboard doesn't have a number pad, press F6.
Apr 11, 2014 | IBM Thinkpad 560 Series Laptop 20h4241...
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
WHEN I PRESS U I O P J K L ON laptop, it type 4 5 6 - 1 2 3
try pushing the key marks "fn" and "F11" at the same time on your key board.
Feb 28, 2011 | Computers & Internet
Hi. My HP keyboard has function symbols which do various things, i.e. open and close the CD/DVD player, for some reason they nolonger work. Could it be that they have been turned OFF ? I don't know how to...
To disable or enable the Fn-functions, try locating them in BIOS using this guide.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=dk&lc=da&dlc=da&docname=c02035108
Otherwise, try hitting these key-combos, pressing the keys down exactly at once:
Dell = Fn + F4
Compaq = Fn + ScrLk
Lenovo = FN + Num Lock
IBM Thinkpad - Shift + Scroll Lock Num
Others:
Fn + F11
Ctrl + F11
Fn + Num Lock
Fn + Shift + Num Lock
Sep 19, 2010 | HP CPQ175KB Keyboard
HP G60-235DX keyboard not working at all
Try to press Fn + Num Lock or Fn + Scrl lock to check if they keyboard will respond. If it doesnt. try to turn off the computer, remove the cables and battery, press/hold the power button for 8 secs. Reinsert cables and battery then turn on the pc. Press again Fn + Num Lock or Fn + Scrl lock. If the keyboard still did not respond, go to the device manager . Click Start > right click My Computer > Properties > Hardware > Device Manager . Then click the (+) on Keyboards, right click the device and uninstall it. Then, go back to the device manager and right click Keyboard then click Scan for hardware changes. Then press FN + Num Lock or Fn + Scrl lock. If symptom persists, call HP to replace your keyboard.
Aug 22, 2010 | HP G60-235DX Notebook
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
On my hp 6735b laptop I would like to turn off the scroll zone on the touch pad if possible.
You don't specify what system are you using. In Windows you have to go to Control Panel, Mouse and Pointing Device properties, and find your touchpad options there, including the scroll areas.
If it's not there, chances are there is a separate application, either in Control Panel, or in the Start Menu, for setting up the touchpad. You can also look in the system tray beside the clock - often there's an icon there for the pointing device.
Nov 25, 2009 | HP Compaq 6735b Notebook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Where is num lock button on Gateway MA7?
Fn+Scroll will toggle the Num Lock
The ison on the keyboard is a purple Lock with the number 1 inside.
Jun 07, 2008 | Gateway MX6920 Notebook
Compaq Keyboard Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
