Question about Acer AL1706AB LCD Monitor
Green light on and no back ground light in it and no pic i turn it off and on and still no good ,but as of now am used and old sceen till i get it fix right now and i bought this computer in jane of 2009.tower works fine but sceen dont please help if you can to help me fix it.and this is for a sceen al1706a.
  • 11,361 Answers
Service manuals: http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1706&kategoria=monitor&kat2=schematics
Please read my guide and look at pictures of failed monitors and bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 10, 2010
I am wiring a 4 pin trailer plug into my 1998 Dodge Durango's factory tail light harness. This vehicle did not come with a tow package of any sort. I installed the hitch and am trying to install the plug...
Hey brother,First thing you need is the relay box that changes everything to the newer harness.Can't wire it like you are,that's old school,till you have that change over box.Use a test ligh to make sure which is left and right signal on truck.Green goes to right,yellow to left,brown to running lights,and white on those 4 wire flat plugs IS defintely ground.Mount the little box/unit to your frame,plug an extension 4 wire flat plug to it,Hook up a seperat ground wire between the trailor and truck with a set of male female wire ends for extra grounding and put on a self tapping screw in frame or on a accesable bolt.Plug it all together and good to go.I've done thes things for years on end,and when they went to this new wiring setup,all I needed do was use that change over box.THAT's progress Bro.
Sep 20, 2013 | 1998-2003 Dodge Durango Tail Light Guard...
WS-55907
1)Pull chassis or center PC board
2)Replace STK392-570 IC's
3)Locate green soldered-in pico fuses = use ohm meter
to find which ones are open ( bad ) = replace
4)Reassemble, test
Nov 19, 2007 | Mitsubishi WS-55907 55" Rear Projection...
No brake lights but fuse is good. Wiring appears okay.
Isnt there a switch on the brake pedal inside under the dash? There should be power going in and out when depressing the brake pedal. If there is a pressure switch, then check it when the brake pedal is up and then depressed. it should have power on one side up, and both when depressed. One thing to keep in mind that I think it goes through the turn signal switch, so if blinkers work, that tells you the wiring is good to the lights, so concentrate on power getting to and out of the turn signal switch.
May 12, 2010 | 1999 Ford Super Duty F 450
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Fads to green with spiraling lines
you may have a short in the picture tube. but from your description it sounds like the positor has failed. really hard from your description but if the positor has failed its very cheap to replace..farr64
Apr 27, 2009 | Televison & Video
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Need a color code for wiring a 4 pole towing kit
I don't know where to get the color code, but you can get yourself a cheap test light at your local parts house, then attach the wire of it to a good ground. Then turn left turn signal, and push the point of test light into each of the connections and when it lights up, makr left turn signal on a pice of tape and apply it to that waire, and so forth till you have identified each of the four wires. One of these wires will be ground so it won't light you up, The outlet has left turn, right turn, and tail lights. The stop lights come out on the turn signals.
Aug 11, 2008 | 1983 Dodge Pickup
Trailer wiring
Hi Smokey,
I've got them for Six and Four wire plugs
Six wire plugs:
Horse, stock or utility trailers:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Jun 29, 2008 | 2005 Ford Five Hundred
Seeing green du42px12x
I don't have a solution, but have a similar problem, when sceens change, red and green pixels form and create a burn in effect from the privious sceen. It happens after the TV has been on for at least an hour. I notice it most when goinf from a light to dark sceen. Any help would be great
Dec 24, 2006 | LG 42PX5D 42 in. Plasma HDTV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Acer AL1706AB LCD Monitor Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
