How can my tv reproduce the audio in my home theater in a normal channel without watching a movie???
  • 2 more comments
  • lopeziivvaan Nov 10, 2010
    the tv is connected to dvd (home theater) by a yellow cable that says VIDEO Left in the middle it has a white that says MONO and then the last one it's red AUDIO Right...as I said...the dvd only came with the yellow one so it's the only one I'm using to connect them.
    What comes to my mind by logic but you tell me.....do I just need the red one....cuz the home theater has it at back ....actually has the three colors???
    ok, but the problem here it is....my tv works with a coaxial cable at back as my cable provider and that cable gives the audio and video signal.......so the thing is this dvd doesn't have the receiver for that cable....what else can I do???
    mmm I don't have a cable box or sat box either!!!
    yes it does... but explain me how to watch and listen the tv channel through those in/outputs??? how can I turn the tv channels in the dvd???
  • 643 Answers
What type of receiver /t.v. do you have
Posted on Nov 10, 2010
  • 3 more comments
  • Tre Elkins Nov 10, 2010
    Your dvd should run into your receiver,then your audio should run OUT of your receiver INTO your t.v. and if you have a cable box or sat box then you might need to run more a/v cables accordingly.
    Your audio cables need to run out of you tv into the receiver
    I don't believe you will be able to do that unless your tv has a/v output (the three plugs) you might need a receiver, or a new t.v.
    Basically you need to get the audio from the cable feed to your speakers, your not going to be able to do this without a receiver or cable box.
    You can't the dvd is only output
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
Hook up everything right,but can't seem to get suround sound from TV. Went to Bestbuy and brought a Digetal Optical cable and it still dosen't seem to give mr that sound like the home theater sound---help!
On the remote press the surround mode button and set it to Prologic movies or music when you are watching TV to get the rear speakers to work.
Or if you have Digital cable TV with Dolby Digital 5.1 content, make sure you have connected theLG to your TV using HDMI v1.3a. There is an audio return channel on this cable which will stream 5.1 audio signal to the LG system.
Mar 11, 2011 | LG LHB975 Theater System
How do I decide which speakers are best for my home theater?
Start with the center speaker as it reproduces 50% of an entire movie soundtrack and over 90% of the dialogue.Next, choose the front left and right speakers. Ideally, these should be as close a match sonically to the center channel speaker as possible.Finally, a Powered Subwoofer is necessary for reproducing the unique Low Frequency Effects channel recorded in most of today's movies.
Aug 12, 2010 | Cobra Audio Players & Recorders
Aug 12, 2010 | Audio Players & Recorders
What outlets do I hook up to on the reciever and the tv for it to play on regular tv stations
Cable Box optical Digital Audio to Coby Digital Audio In. (This brings TV-related multi-channel and normal audio into the Coby so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the Coby on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
Mar 01, 2010 | Coby DVD938 Theater System
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Desire Audio for Theater System when watching Tv.
Have you checked all the channels connected correctly refer to the user manual once.
Jun 25, 2008 | Durabrand STS92 System
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
hi there
you can hook it up to your tv and make your regular shows sound like theaters too. all you have to do is check with your tv menu and look for a setting there which is similar to hall,theater...etc. not all audio settings has this though.
hope this helps.
Feb 11, 2008 | Audio Players & Recorders
I can not get model sts96 to display on my tv
Dec 17, 2007 | Durabrand STS92 System
19 people viewed this question
 Grubhead
Grubhead
