Question about Whirlpool AWM6100 Front Load Washer
Wash cycle commences then after a few secs the door open light flashes and cycle stops. But the door is still locked and takes a minute or so to unlock after turning machine to off. It didn't happen when we tried operating on rinse/spin cycle. Lots of clicking sounds happening too. Can you help please?
  • karenlott Nov 15, 2010
    thanks - have purchased new electronic wiring box - seems it was the timing - it's coming via ebay & fingers crossed spending $150 on that will save purchasing a new machine.
    President:
  • 1,891 Answers
Replace door latch assm or take the time to ck the wires from the door sw to the prosser . look for pinched or warn thorugh . wires or loose connections . very common complaint . it is most likley the wiring .. mm hope this helped feed bck pls .
Posted on Nov 10, 2010
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Hi
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting fixya.com
Oct 24, 2009 | Dishwashers
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Whirlpool frontloader 6AWM8143
It's faulty contact the manufacturer or the seller
Feb 02, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM6100 Front Load Washer Logo
292 people viewed this question
Dan Webster
Dan Webster
Sal De
