Have a p5 code souns like condensate pump stays on all the time.
  • 81 Answers
What kind of unit it is? brand model. most models dont have pumps? do you mean the compressor
Posted on Nov 10, 2010
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
P5 error code floorstanding AC Changhong
cara menangani erorr P5 pada ac floor standing changhong????trims infonya
Jan 09, 2014 | Heating & Cooling
I have a 1989 S10Pick up with a 2.8L, won't stay running. I can pull the ecm b fuse it will run about a min then quit, I've changed the fuel pump relay and checked crounds still has this problem?
if it runs for about 5- 10 minutes before it stops, when it stops remove the gas filler cap, do you hear a suck inrush of air when you remove the cap?
Dec 15, 2013 | Twister Auto Parts 89-93 Chevrolet S-10...
Hitachi error codes p5
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. West Palm Beach Air Conditioning
Sep 24, 2013 | LG Electronic Window Air Conditioner
Condensation in hyandia i10
Have you checked your coolant level? souns like you may have a heater core leak.
Feb 15, 2013 | 2010 Hyundai i10 1.2
I keep getting a p5 error code on the indoor unit of my klimaire minisplit
I have a 3 unit split.
I found out that you can not have one unit set to warm and the other to cold. The compressor doesn't understand it.
Cycle off on and quickly re mode to Cool .
Do it to each unit and you will get it to stay on and then you can adjust.
Took a while for me but it did stay on after switching Mode at startup
Jul 12, 2011 | Cfm Klimaire KSWG009H113 Split System Air...
Cut out with P5
P5 is possibly drain pump malfunction. check pump is working and also suction and exit lines are clear. Hope this helps -
Jul 22, 2010 | Mitsubishi Heating & Cooling
Overheating
Souns like to me that the thermostat aint opening up when it needs to id check to see if it was installed right. In just for **** in giggles id check the water hoses in make sure they all was hooked up rite
but first id check your thermostat
Feb 26, 2010 | 1993 Acura Legend
Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
May 26, 2009 | Hayward 116k HeatPro Heat Pump HP3100
Washer stops washing and gives a p5 trouble code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
