Question about Cadet Manufacturing C152 Com-Pak Plus Heater
I have a cadet heater not working. When I try to push the reset button it does not seem to go in at all. Do I need to replace the complete heater unit or could it be the thermostat?
I had this same problem, which required a new heater. The thermostat tested fine. A bypass of the thermostat switch was attempted and the unit still would not work. The reset switch had never tripped to indicate a problem.
Posted on Dec 13, 2010
  • Josh Peck Jan 20, 2014
    The "one shot" needs to be replaced. It is a back up safety fuse.
My reset button keeps tripping
Reset button...Is it also a breaker? After they trip a few times they can become weak. Also if possible check all the wiring and make sure all connection are tight and secure.
Oct 21, 2012 | Cadet Manufacturing Register Plus RM202...
Grandson put something in front of cadet heater. Now it's not working. Is there a reset button?
Yes there is a reset. Take of the front grille and you'll see the button on the front marked "HEATER RESET - PUSH". Make sure your unit is clean and free from lint and dust, which will accumulate over time and use. Inspect the unit for any signs of scorching or damage from whatever was put in front of the heater.
Dec 08, 2010 | Cadet Manufacturing C152 Com-Pak Plus...
Cadet C202 Stopped working. I took the grill off and tried to reset it but the reset is stuck. What can i do?
I have the same issue on my Cadet c202. Did you ever identify a solution on this?
My thermostat turns on, but the heater does not. Reset switch does not appear to be working, or this isn't the issue. I'm hoping I don't need a new heater.
Any help would be appreciated.
Oct 26, 2010 | Heating & Cooling
Heater stopped working after my daughter was standing in front of it. instructions said to cut power, hit reset button, not didnt work
heaters have a diode inside and it must of triggered it and perhaps blew it out if the reset doesnt work after a couple more times put it in the coll and see if it after over nigth set out will work the nest day keep me posted
Jan 25, 2010 | Cadet Manufacturing CADET SL Series Small...
Top thermostat reset button kicks out
The top button is connected to the top heater element  which is likely shorting out. Drain the tank below the element that the thermostat is attached to. Remove and replace the element
Jan 24, 2009 | RELIANCE ELECTRIC WATER HEATER
Cadet wall heater
Since I don't know what model of heater you have there might be a reset button to reset or an over temp switch (button sensor with 2 wires going to it) that needs to be replaced. You might check the recall list to see if this one has been recalled and should not be used.
Sep 11, 2008 | Heating & Cooling
Cadet heater quite working
that round metal thing is called a klixon overload. look on the side of it and an amperage range should be there. replace the unit and the element should work unless the element itself is blown. check for continuity across the element with your meter with the wires disconnected.
Nov 03, 2007 | Heating & Cooling
Cadet Manufacturing C152 Com-Pak  Plus Heater Logo
1,263 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
